Question about Pride Mobility Products Jazzy 1103 Ultra Electric Wheelchair with Powered Seat Lift by Pride Mobili
I still need to know where the model number is located on a Jazzy
My question applies to a 5 year old Jazzy.
Can I use the serial number to find out what Model Jazzy Power Chair I have
Hi batteries for jazzy GT. ::: UPG UB12350 12V-35AH internal thread. E/Bay sell a 2 pack US $119…99 Cheers
May 05, 2017 | Select Health & Beauty
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
How do I tell what year my Jazzy is with my serial number ?
call 1-800-800-8586 tech support will tell you from the serial number
Sep 21, 2012 | Health & Beauty
How to reset controller on jazzy power chair
yellow light is flashing and i can't turn chair off. still operates.
Jun 20, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Need to know what year is my washer set
The date of manufacture is determined by the SERIAL NUMBER, not the model number. The serial number will be located on a nameplate (with the model number) along the wash tub rim under the lid.
The following link explains how to read the serial number to determine the age:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The 2nd digit in the serial number will identify the YEAR is was manufactured. The first two numbers, following that digit, will determine the WEEK (52 weeks in a year). This same information applies to all your other Whirlpool appliances.
If you have any questions, please post back and let me know. I hope this helps you.
Dec 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Jazzy 1113 ats won't start
How old are the batteries? If you've had them for a few years it might be time to change them. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1113 http://www.replacementupsbattery.com/UB12350-NB.html
Nov 04, 2010 | Pride Jazzy 1113 Power Chair
I want to know in what year the bike with this vin number was manufactured
well in the good old USA if you have a 16 digit VIN number then the 10th digit will always denote the model year of the vehicle and that applies to all vehicles with a 16 digit VIN. The coding for them simply starts with the letter H and they leave out a few choice letters such as I O Q Z and then it starts into numbers after Y and honestly after the year 2009 Im not sure what they have gone to as Im not currently working in a dealership anymore, however here is a chart that I made to help ya get it figured out. Good luck and enjoy your summer.
h = 1986
j = 1987
k = 1988
l = 1989
m = 1990
n = 1991
p = 1992
r = 1993
s = 1994
t = 1995
u = 1996
v = 1997
w = 1998
x = 1999
y = 2000
1 = 2001
2 = 2002
3 = 2003
4 = 2004
5 = 2005
6 = 2006
7 = 2007
8 = 2008
9 = 2009
May 21, 2010 | Motorcycles
The battery on the Pride Jazzy 1103 will ot take a
Have the batteries load tested. If they have sat to to long then they will need to be replaced.
Nov 22, 2009 | Pride Jazzy 1103 Ultra Standard Power...
What kind of Jazzy select 6 power chair does my Mom have? Serial number J92037090688C30. We live far away from each other and I need to know what she got.
Here's a link to Pride Mobility, maker of the Jazzy wheelchairs. This takes you to the Select 6; there's also a Select 6 Ultra. Just click on models and it will display all of their line of equipment.
Sep 30, 2009 | Select Products Power Chair Pride Jazzy...
Jazzy 115 will not move. Controller has 3 red and one amber bar flashing
Pride doesn't make a Jazzy 115. Please check your chair and owners manual to get the correct model so we can help. How old is the chair? The flash codes you are getting depend on the model, year it was born, and the tkype of controller installed.
Also, the flash code should be literally, flashes. 2 lights flash twice, stop, then go again, etc. They all mean something, so repost with more info please.
Jul 07, 2009 | Electric Jazzy 1115 Power Wheelchair
Pride Mobility Products Jazzy 1103 Ultra Electric Wheelchair with Powered Seat Lift by Pride Mobili Logo
57 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Will
Level 1 Expert
Marvin
Marvin
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
