Question about Toys
John deere d105 gas pedal became loose in under 4 hours of use
I was using a john deere d105 series lawn tractor to cut grass and all of the sudden the gas pedal became loose and unusable. when it is in forward or reverse the pedal lays all the way down but the tractor doesn't move. Feel like it is no longer receiving any resistance like it was when i was using it.
    Top Expert:
  • Toys Master
  • 64,733 Answers
Sounds like the spring came off look underneath and see
Posted on Oct 20, 2019
6ya staff
SOURCE:
tripletauto
TripleTauto
  • 1450 Answers
SOURCE: John Deere LT190 Lawn Tractor transmission problem
is it hydrostatic drive? if so you probably need to change filter and fluid
Posted on Oct 01, 2008
SOURCE: John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Posted on Mar 23, 2009
romney2012
  • 156 Answers
SOURCE: I have a John Deere Ride on Toy stuck in reverse
Are the actual shifter levers not engaging or are the switches not clicking?
These Peg Perego Parts are available at http://www.shopjandl.com/, but I would check to make sure if it is the switches specifically or the levers under the shifter.
It is simple to check the shifter by taking the 2 screws out that hold the shifter in.
Hope this helps.
Let me know what you find.
Posted on Apr 16, 2009
Joe Hogan
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
ROB
  • 858 Answers
SOURCE: Peg Perego John Deere tractor 12volt will only
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
Posted on Aug 17, 2009
How Do i reset the service light on my John Deere d105
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
John Deere D105 Lawn Tractor Technical Tech Service Manual
May 22, 2017 | John Deere Garden
John deer d105 with 8 hours won't go up same inclines it went up last week
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
Sep 22, 2016 | John Deere Garden
John deere d110 not cutting grass
check belt and pulleys --if belt to loose wont turn blades to cut the grass
Aug 31, 2016 | John Deere D110 42 in. 19.5 HP...
Cutting grass but it isn't going into the bagger?
grass catchers need special shaped or good blades to throw the cut grass into the bag
check/ replace the blades
May 06, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Why does my riding tractor leave a strip of grass that isnt cut
It is probably an indication of worn mower blades. Installing new ones should solve the problem. Hope this helps.
Bob
Jul 31, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
John Deere D105 Lawn Tractor will not go forward
does it go in reverse ??? if no, suspect the belt, or did you have the wheels off of it recently ??? if yes then still suspect the belt or a bad transmission
Nov 23, 2013 | John Deere Garden
John Deere x520 pto issue
not trying to insult your intelligence, but did you make sure the belts were installed properly.it does happen to the best of us..good luck
Apr 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Toys Logo
1,024 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
