Our Jacuzzi brand premier hot tube After a water change it would not start up at all we pressed the up and down at the same time and F1 came up. we have tried empting the water and trying again. we have run the hose into the intake to blow out air. we have tried to start it with out the filters and still nothing. it is dead. any suggestions?
SOURCE: Leaking pipe in a jacuzzi hot tub
The only product I know of which will do what you ask is an item called Plast-Aid Acrylic and PVC repair kit. Google it and you will find the website. It is about $20. and it works like a charm. good luck
SOURCE: jacuzzi hottub flashes f1 code. Tried hose in
The F1 code on my Jacuzzi is just the setting for the filteration mode. If you press the + and the - sign at the same time than release. Then press the warmer + or cooler - to select filter mode F0 thru F6. If you are getting a FL1 code means the flow switch is malfunctioning.
SOURCE: "Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
There are two things you can check, there is a tranformer that plugs into the main circuit board(usually a four wire plug). Unplug and check pins for good connection and then reconnect There are usually one or two fuses inside the control box mounted on or near the circuit board. Turn off power to spa and pull fuses and check continunity. This is a good start.
SOURCE: I have a 1988 Jacuzzi brand hot tub and I need a
Ekk, Jacuzzi went bankrupt in 2006. Best of luck to you.
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
