SOURCE: Problem with Wall-e Blue Ray movie
i would say the problems comes from the way the company formatted the movie onto the blu ray discs. and i would say that there will most likely be a recall on them. if anything connect the manufacturer of the movie. hope this helps you.
SOURCE: Problem w/Samsung BD-P1200 Blue Ray Disk Player
Hello mljackson197,
This indicates a problem with the pickup head. First I would suggest cleaning the laser head with a disk made for that purpose. If this does not work, then I would suggest (if you have a background in electronics) taking the cover off and checking the bias voltages on the laser pick head (comparring them to the schematic values). What I believe is happening is just a dust problem, however if it is a circuitry problem, contact the manufacture or use the schematic/service manual to locat OEM parts.
I would, however try to clean the pickup head first.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
SOURCE: blue ray quit recognizing non BR disc
The non-blu-ray laser lens needs cleaning.
Try not to use a blast of compressed air.
Radio Shack has a lens cleaner ($13). it is an audio CD with a row of brushes on it.
Read & follow the directions.
SOURCE: blue ray disc want play in samsung bd p1600
Is your software up to date. If player has old software and you try playing some newer Blurays, it wont play.
SOURCE: Blu-ray 3D movies doesn't play through a Bose home
Upgrade the firmware of your Bose home entertainment system.
http://worldwide.bose.com/downloads/nl/web/home_entertainment_system_download/page.html
Good luck,
Ronald de Vries
