Watches Logo
A
Anonymous Posted on May 05, 2014
3R260UWH REPLACE BATTERY
I need to replace the battery in Gucci 8505 Series 18535 what battery do I use
Any watch maker should be able to tell you what battery is needed and/or replace it for you.
Sep 19, 2014 • Watches
Replace battery rosendahl watch 43250
To replace the battery in a Rosendahl watch with the model number 43250, you will need to follow these steps:
  1. Remove the back of the watch by using a watch back removal tool or a small flathead screwdriver to gently pry it off.
  2. Take out the old battery and discard it properly.
  3. Take the new battery and orient it so that the positive side is facing up.
  4. Place the new battery in the watch, making sure that it is positioned correctly and securely.
  5. Replace the back of the watch by pressing it back into place. Make sure that it is securely fastened.
It is important to handle the battery with care, as they can be damaged if they are dropped or handled roughly. If you are uncertain about replacing the battery yourself, you can have it done by a professional watch repair technician. They will be able to replace the battery safely and ensure that the watch is in good working order
Invicta 6212 battery replace
open rear cover, replace battery.
Replace battery
Best way here is take it to a jewler or even Walmart and let them replace the battery for you.
5helpful
How to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
9helpful
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
1helpful
I want to replace the battery in my chopard and i dont where
Open watch caseback. Undo the contact. Memorise numbers on battery and buy exactly the identical one. Replace the battery. Fit the contact back. Close the caseback. Reset the watch.
Mar 31, 2009 • Watches
1helpful
2answers
Need to replace battery
Take the watch to a jewlers, let him replace the battery they usually only charge for the new battery,
and they do not cost much.
2answers
Battery Replacement
I thought you are supposed to touch the neg side of the battery
Top Haurex Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Haurex Watch Expert? Answer questions, earn points and help others
