Life Fitness 91Ti Treadmill  Logo
A
Anonymous Posted on May 05, 2014
Init code What is problem ?
Brother DCP-J125 says unable to init 48. AF see troubleshooting guide
https://www.google.com
search gives the following links with suggested fixes:
https://help.brother-usa.com/app/answers/detail/a_id/144764/~/unable-to-init.-af
https://www.ifixit.com/Answers/View/332612/Brother+MFC-J825DW+Printer+%22Unable+to+Init+AF%22+Error+Code
https://support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod=dcp6690cw_eu_as&faqid=faq00000565_011
What code do i enter after reset a casio te-2400 cashregister
There is no specific code. You need to create one based on your needs, currency type, country etc. In the programming manual, you'll see the table for creating a MAC (init) code. Run through the table to create the code and then input it during the init process. If you don't have your programming manual, one of the users has it here:
https://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
Brother error code dcp-j 125 unable to Init 50
hi good day! the printer is error 50 due to a paper or some sensor error.. open the printer, or dismantle, clean the sensor and wash the pump of water and change the waste pad of new absorber. locate the sensor under the pump, clean it of alcohol.
Scanner Init error!!
some solution ? i have the same problem :(
Casio TE2200 stuck in INIT mode and wont let any cashier log on. I have just done a factory reset and set time, date, dept names, and cashier names. Now no-one can log on or off and it seems the till...
It sounds like you might have used the wrong clerk system in your MAC code. If you use a single clerk button on keyboard, you need clerk code set in the MAC code. If you use the clerk buttons at the top of the keyboard, you need to set clerk key in the MAC code. If you tell me the MAC code you used during the reset, I can see which system you are using.
If anyone needs a Casio TE-2200 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Asus striker extreme motherboard comes up with cpu init code on lcd screen
You will probably have to go into the BIOS and set defaults. You can also Goolge the computer to find the jumper that can be used to default the BIOS back to factory spec's.
you can also call Asus and have them send you another BIOS chip, it plugs right in.
(found this 1 on the Internet, Goolge "cpu init code + Asus")
1helpful
2answers
Error code: init unable 51
It sounds like a switch actuator is stuck down by a piece of paper in document feeder..
Unplug power cord for 10 seconds
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
