SOURCE: change spark plug wires on 04 kia sedona
REMOVAL OF THE PLUGS:
Do not attempt any maintenance on spark plug if engine is hot.
1. Disconnect negative battery terminal.
2. Carefully remove high-tension leads.
3. Use compressed air to blow any dirt or debris from around spark plug hole.
4. Check that spark plug fits squarely in spark plug socket and remove spark plug.
Raise a vehicle and install SST(OK552 131 001) in order to replace cylinder 2, 4, 6 spark plug.
INSTALLATION:
1. Install spark plug into cylinder head.
Tightening torque : 18~22lb-ft (25~30N·m, 2.5~3.0kg-m)
2. Reconnect high-tension leads.
3. Reconnect negative battery cable.
Hope this helps and simple to understand. Good luck
SOURCE: 2005 kia sadona belt replacemnet
This guide will help you. Just provide an email and log on.
http://www.kiatechinfo.com/
SOURCE: The rear wiper on my 04 Kia sadona won't work. The
turn it on go feel the wiper. the gear that moves it mite have stripped. or the threads on the wiper arm. you should feel if its moving if not you need 2 change the wiper motor
SOURCE: how to change transmission fluid and filter in my 2003 kia sadona
ITS VERY MESSY UNLESS YOU HAVE A BIG PAN TO CATCH ALL THE TRANNY FLUID, BRING IT TO A TRANNY SHOP INSTEAD, PAY SOMEWHERE FROM $75 TO $100
SOURCE: which pully do you loosen to change the fan belt
Hello dbhammons1 and thank you for asking your question here on fixya.com.
I have actually written a general information article that will walk you
through the general process of changing the fan belt on your 2002 Kia Sedona. It will also point you to the resources you need for
getting the diagrams of how the belt needs to go back on.
Here is a link to that article:
How to change the fan belt on your 2002 Kia Sedona
If this has helped you in any way, then feel free to follow my Twitter account for more great money saving tips and tricks. twitter.com/acoates23234
I follow back, too. :)
Thanks for reading.
