Samsung LN-S4695D 46 in. LCD HDTV Logo
A
Anonymous Posted on Aug 15, 2017
When I turn the tv on I get a full screen of flickering green and pink..If i turn it off and on again the picture comes on .But this happens every time I turn it on. Also happening ,when the picture does come on,the tv has a horizontal picture flickering.This happens mostly on replays and is real bad when I turn on the guide on the remote control.It also does this when unhook the cable box.
5 Related Answers
Anonymous
  • 192 Answers
  • Posted on Jun 03, 2007
SOURCE: LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Anonymous
  • 335 Answers
  • Posted on Jan 04, 2009
SOURCE: green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jose Garcia
  • 453 Answers
  • Posted on May 08, 2009
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Anonymous
  • 304 Answers
  • Posted on Jul 17, 2009
SOURCE: Pink and green lines and double picture.
Replace the main bd. Have a trained Samsung tech troubleshoot to confirm.
Anonymous
  • 927 Answers
  • Posted on Jan 02, 2010
SOURCE: Self- reboots at start-up, then shows picture but with pink dots.
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. It is the board to the left and you notice that the four cap tops are swollen.
It is easy to replace get a stanard solder pencil and you are in business.
Thanks for using FIXA, BIG IRISH.
Testimonial: "Thanks for the advice, guy. I already replaced the 2 that were swollen, and now my TV is awesome again. Will replace all caps if it happens again."
What is wrong with my Sanyo TV?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
I have a RCA L42FHD37 LCD TV. It comes on with picture and sound. After about five minutes the pictures color turns pink and green but still has clear picture and sound. What causes this to happen?
T'Con board fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
My TV will flicker at times and go completly black for a period. I unplugged everything and let it sit for about 12 hours and the TV worked fine the next day. The following day the TV again flickered and...
The screen flicker than go blank,does it still have power to the tv set?Yes,than this cause only can be causes by only 2 boards in the tv can causes this problems,if tv power still stable for the set.The T-CON board it shorting out and dying for this problems to happen or worst case causes the Main board tv Tuner signal board it dying.The T-CON board the priced it is cheaper and could cause this problems too.Tries change this T-CON board first,see what happen.This board T-CON board sit at the bottom in the middle of the LCD screen panel to decodes pictures pixel before it go onto the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Samsung HLR5067W: Screen goes black - Audio Remains. Several months back my 5 years old HLR5067W started displaying the following behavior: - Launches OK - After running for a while (anywhere between...
When was last time you replaced Lamp? Ballast Board is what powers the lamp on.
Lamp Fan, if it is defective it will shut lamp off to protect it, if it is Not cooling the Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Encompass Parts Distribution has 10 Ballast Boards in Stock for $68.96 they also list Service Manual Free for this Model# 1-800-638-3328
1helpful
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
1helpful
TV KOLIN 21"
hello.... do you have any speakers near your television? what color is the circle your talking about? Do the green,pink colors are scattered all over the screen and specially on the corners?
If you have or had speakers near your tv? then do this try to get a magnet.a magnet on a speaker would do.what you have to do is to place the magnet near the screen of the tv approx. above the green,pink color (turn it on first).you will notice the that the color will react with the magnet try to pull it on the side you will notice that the green,pink color is moving on the same direction do it until its gone.NOTE make sure youll not scratch the screen ok.email me what happened. [email protected] GOODLUCK
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Pink Screen
Most likely the green electron-gun in the CRT is failing.
Jerry G.
1helpful
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
