Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
A
Anonymous Posted on May 05, 2014
Phone shuts off during incoming call when paired with jabra freeway
5 Related Answers
A
Anonymous
  • Posted on Apr 28, 2008
SOURCE: Pairing with a phone
Turn the headset off. Then hold the main button (not the volume up or down button, but the button with the phone on it) for 7-8 seconds. When the light is a solid blue it is in pairing mode.
Anonymous
  • Posted on Aug 23, 2008
SOURCE: Cannot pair a7010 with Plantronics Voyager 520
The actual problem was Plantronics, I was not turning on pairing mode. I was confused with quick pair which starts not immediately after turning on, but you need to hold the button longer until led will start blinking blue and red.
Anonymous
  • Posted on Sep 09, 2009
SOURCE: how do i pair my jabra w/my phone. cant find
hold down the button till the light turns solid blue, then let the phone already in bluetooth mode find the jabra, it will ask for a password, enter 0000
Anonymous
  • 4 Answers
  • Posted on Dec 16, 2009
SOURCE: my jabra headset won't pair with my phone--my
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Testimonial: "This worked perfectly! Thanks!"
Anonymous
  • 583 Answers
  • Posted on Feb 07, 2010
SOURCE: I cannot get my Blackberry Storm to pair with my Jabra BT2070.
You have to first put the Headset into discoverable mode. According to the Jabra website, this is done by pressing and holding the end/mute button until the light comes on steady. Follow the procedure for your phone to pair a bluetooth device to it. The PIN code will be 0000.
GALAXY 21 mobile paired to Jabra Tour 5G headset
Delete Jabra from Phone and reboot. Tell phone to search for Bluetooth devices. PRESS THE BLUTOOTH BUTTON ON JABRA! Now you are Paired. Make sure phone is not on Mute.
Jabra Tour - Support
https://www.jabra.ca > Support > Jabra Tour
Get support for your Jabra Tour. Find all product guides, resources and FAQs.
How to accept the incoming call.
has it been 'paired' with your phone via bluetooth?
The freeway does not respond to any phone commands
Be certain that your bluetooth is fully charged, then be certain you follow BOTH your phone's and your bluetooth devices instruction for pairing.
Exactly what phone commands are you trying to get your bluetooth device to respond to?
2answers
Cant pair my iPhone with jabra sp5050
forget the headset
turn bluetooth off
turn the headset device off
reboot phone.
try again
1helpful
How do I "pair" the Jabara Journey with a I Phone 5C?
most pairing when asked by the device requires a 00000 passcode
but you need to set the jabra and the iphone up for pairing
here is a link for jabra the iphone should see it when the jabra is set to set up mode..
http://www.jabra.com/support/Jabra-JOURNEY_100-47300000-15
1helpful
Jabra freeway won't go back to factory settings
Press Mute, Answer and Voice at same time and hold until the unit makes a three toned sound. Power Off Unit then power back on. Unit will automatically enter pairing mode
What are the advantages of the Jabra drive over the jabra freeway or tour?
The Jabra Drive is superior because it can be paired with two devices simultaneously. It also offers special noise cancellation technology, so the person on the phone will not be distracted by hearing the low murmur hums of your car
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing 2 mode
Make sure that the headset is on.
Press the answer/eend button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
3. Your phone will find the Jabra BT160
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
repeat steps 1 to 3.
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there www.jabra.com
ARTGIRL
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
