How do you boot a compaq presario CQ60-212us from usb drive?
You have to make a boot able USB drive, Internet is full of how to do it
4 years late.
best is boot it out the door to the trash.
or RTM.
ever read the manual first?
PC side, method is there, read it?, making the stick boot is topic 2 , google RUFUS.
Jsut about all the computer now when the computer boots hold down the f12 and then choose the usb drive to boot. if it does not show the usb drive yo might hav to go into the cmos and change the settings. then again it if is aold computer then it might not have that option
400 answers all years late, why,
Posted by Anonymous on May 05, 2014
a bit late no?
Ruland why not answer current posts
and not in he dead files.
yah think?
not only that but your posts SLAM all current post down,hidden , is this fun for you doing that dirty deed?
a 4 year old post on USB boots
the PC still has a HP support page read it?
https://support.hp.com/us-en/product/com...
page1 clearly states it does!
ASSUMING the PC runs at all or is not bios password locked up,. these are the steps.
it came with VISTA (era)
the build date is 2009-2011, so is not too old
most PCs that year boot to USB ok.
but how,? well here is the logical list.
1: you must build a bootable usb thumb drive
and test it on a modern PC first to see if it does boot. (first)
2: then boot it on this old CQ60
Hammer the f9 key(at power-on-pressed)
3: next power on and hit the magical HP F9 key,
this pops the magic, F9 boot on the fly window. you see the USB stick there and pick that. next. (must)
next and quickly hammer space bar, and this causes the USB too boot or CD/dvd if used.
if not it will never boot , not "hitting any KEY" now, Space bar is the most easy to hit fast ,IMO. (this step is called El Torito rules!)
there is your answer, and is not told this at this level in the HP books,
fodder for the necro world.
here.
now turbo mode (short steps)
insert usb stick
hammer f9 see menu pick stick
hammer space
USB boots.
these 4 steps, work on all modern HP PCs.
say 2008 up. 1 decade old or newer now.
4 years late you answer? why?
f9 is HP key not F12
necro 4 years.
the key IS F9 not F12
F12 is dell , , Compaq is HP is F9
the manual told you what key it is, and states F9 clear as day. I even read It for OP anon.
1: make a bootable USB first and test it on many PC first to make sure it is good and does work not just one PC , OK>
2: Then power on and under 1 second, hit F9
see your USB stick in the tiny menu?
yes, good, (2b (no)
then click that and the after that quickly tap the space bar, until the USB boots.
4: if this fails try all USB ports on PC.
some PCs the USB3 port are not supported for boot.(10 year old PC this is common then for sure my HP 8540w)
a transitional year for USB3.
5: if step 2b fails upgrade your BIOS.
ask maker of PC how, not here, only there.
What your BIOS can do or not do is not documented by HP. (seem any maker too)
the book says, if things seem wrong here as we write about USB, then the BIOS needs to be upgraded. (cute no?)
HP does not have manuals on all BIOS upgrades. nor do they show each BIOS update page and a file showing what was added , changed or deleted,, also know that on some PCs, for sure w8 and newer,
the BIOS can not be REGRESSED now. (laws)
can go forwards not backwards.
most of the newest BIOS upgrade are the endless bugs in UEFI,(security)
test the USB boot stick on a modern PC
not one running XP,win2k,w98. or older.
SOURCE: Drivers and utillities for Compaq Presario CQ60 140EK
From HP Support site, getting CQ60 to work with XP:
Intel Chipset (install and reboot before other drivers):
http://tinyurl.com/54r6dt
if you have Nvidia video graphics
NVIDIA GeForce 9200
Nvidia ForceWare X 177.98 for Windows XP/2K 32bit, here:
http://tinyurl.com/6dz435
3-step process to install:
1. Download driver, double click and select extract,
2. Download modded INF and replace original INF in extracted folder,
3. Install & reboot.
MS-UAA (required with a reboot before intel Video and Audio driver)
here:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
if you have intel graphics
Mobile Intel 4 Series Express Chipset Family Graphics
http://tinyurl.com/48lunj
Conexant SmartAudio 221
here:
http://www.mediafire.com/?dg0cmmkm4y4
Use this for audio. Unzip to a folder.
Run installer. if it errors use Device Manager.
From Device Manager,right click "Audio Device on HD",choose Update driver,
No to connect,
Install from a list or specific location,
Select Don't Search, I will choose the driver to install,
For the Hardware Type select 'Show All Devices'
Remove the check from "Show Compatible Hardware" and click on "Have Disk".
Next...browse to the unzipped folder and choose the "WiSVHe5.inf".
Ignore XP when it complains.
Reboot.
Conexant HDAUDIO Soft Data Fax Modem with SmartCP Driver
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33839.exe
if you have Atheros Wireless driver
here (your VISTA driver):
ftp://ftp.hp.com/pub/softpaq/sp39001-39500/sp39403.exe
or if it does not work try here:
http://www.megaupload.com/?d=P8I57N0S
if you have intel wireless
here:
Intel PRO/Wireless Drivers
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38890.exe
if you have Broadcom Wireless
here:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39912.exe
Realtek usb 2.0 Card reader:
http://tinyurl.com/2bj95k
Realtek RTL8101E Family PCI-E Fast Ethernet NIC Driver
http://tinyurl.com/4ssd97
.Net Framework(before Quick Launch):
http://tinyurl.com/758p8
HP Quick Launch Buttons
ftp://ftp.hp.com/pub/softpaq/sp40001-40500/sp40139.exe
If you have Bluetooth,
The HP Integrated Module is your Bluetooth Wireless
here:
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38983.exe
If you had for 7 unknown devices (buttons drivers)here:
http://www.mediafire.com/?nnnzjmojcjy
Installation --> right click machine.inf, choose install.
Good luck.
SOURCE: Compaq Presario CQ60-211DX keyboard not working
open the laptop and bring out the keyboard .
whash it with Alkohol and after 20 minuts dry it
and after 3 hours install it and test.
if dosent solved i have it .i can send u
SOURCE: compaq presario cq60 keyboard
If the problem is intermittent then the problem could just be
foreign objects like crumbs and hair that's trapped under the keys.
Turn
the laptop off and stand it on it's side with the lid open. Get a soft,
dry paintbrush and brush the keys, gently tap the keyboard in various
places with the back of the paintbrush to help dislodge anything that's
trapped.
Once your satisfied all the keys are clear turn the laptop on and see if it has made any difference.
If it has not then you may need to replace the keyboard.
Good luck.
SOURCE: webcam in compaq presario CQ60 not working after
what vista did u install. if it is 64 bit? most programs are not compatable with it. if it is 32 bit google the vista driver for ur laptop camera and install.
SOURCE: Compaq Presario CQ60 touchpad problem.
Boot your laptop. After the laptop shutdow and just at the screen light up, hit f1 or f2 key to enter any setup screen. Then hit F10 to exit. after reboot, your touch pad should come back. It worked for me many times.
