Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
I have lock my Kingston from imation lock.
I had running imation lock.exe on my 1 gb kingston data mini traveller. When i run my flashdisk, suddenlly i had message box ''please insert a disk into drive i: ''. If i want to format the usb flashdisk, the massage box warn me again if computer cannot access my usb. Please help me....
cause before running that damn software my usb is work....i dont want to cange my usb flashdisk. thnx
  • 212 Answers
You can try formatting it from the disk manager.
plug in the flash drive and remember what drive letter it gets assigned. right-click 'my computer' and choose manage from the drop-down menu. in the following window, click on disk management (under storage) on the left, then right-click on the flash drive and choose format...
Posted on Jun 22, 2009
SOURCE:
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
Kingston data treveler not format
Hi qais_baba
1...Plug your Kingston data traveler in to your computer
2...Go to desktop and open "My Computer"
3. You will see your Kingston Data Traveler listed there
4...Right click on the Data Traveler
5...Click on "Format"
This will format your Kingston Data Traveler
Please rate me
Bud
Sep 25, 2012 | Kingston DataTraveler 101 G2...
My flashdisk kingston data traveler 2 gb, unreadible and when I touch it is hot. what is the problem and how to reparing it?
The data chip inside it is shorted so take it out of the pc or it will fry it and that will cost a hell lot more. The stick is defective, can't be repaired so junk it.
Dec 22, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
KINGSTON USB 2.0 4 GB IS WRITE PROTECT. I want to format it, but a write protect problem is generated in.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 05, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I had problem with imation lock
how format flash imation 8 gb write protected
Mar 25, 2009 | Electronics - Others
I had run imation lock on kingston 4 gb and now its says "Please insert the device or run this"
its a little tricky, just try it
  1. unplug ur usb drive
  2. double click the imation lock
  3. when the message appear "Please insert the device or run this utility as privileged user" plug the flash/usb drive quickly
  4. USB will start working
  5. run the imation lock again and disable the password protection
  6. delete the ugly imation lock from ur system
i hope u find it use full, plz give ur feed back at: masood@inbox.com
Jul 28, 2008 | Computers & Internet
ABOUT MY 2GB PEN DRIVE WARRANTY
Here's what you should do. actually I prefer using DOS to do this. ok, so fire up the DOS and goto C:
this virus actually put two files on each partition that It will infect, autorun.inf and the .vbs file which contains the code of the virus. currently the attributes of these two files are hidden, read-only and system. so using attrib command, type:
attrib -h -r -s autorun.inf
attrib -h -r -s m*.vbs
del m*.vbs
del auto*.inf
also look for the windows folder and look for the other .vbs file of the virus and change its attribute.
not yet done.
activate your task manager(ctrl-alt-del) and look for wscript.exe, you should end this task.
take not you must do this in every partition or flashdisk that have been infected. Take note you should also check the registry since this virus append it's .vbs to the [Run] field of the registry and also it alters the Title of your Internet Explorer to Hacked by Godzilla.
after your done, you need to reboot your system.
Jun 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
349 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
