https://www.northerntool.com/.../1577544.p... Northern Tool + EquipmentCall NorthStar Product Support 1-800-270-0810 .... -During transportation take precautions to make sure pressure washer will not tip ..... A- Low oil shutdown.
check all hoses going to water pump and make sure they are not leaking, if hoses are not leaking then pump is going out. need to replace asap, if car has northstar engine DO NOT GET IT HOT average cost to replace head gasket on northstar is $2300.00 plus
This sounds like you have a bad seal in your pump and the loose piece is probally a piece on the shaft of the motor called a water slinger. This is just there in case your seal goes bad and leaks water it will spin with the motor and sling the leaking water out and away from the motor so a small leak does not ruin your motor. But you will still need to replace your seal and "O" ring.
Pump will power up, but when I attempt to use the wand the motor sounds like it is running on one leg & blows circuit breaker----Ser# 1575551-1101 5160 Model #1575551E
