Question about Jensen VM9424 Car Video Player
Jensen vm9424 sd slot whats viseo format - Jensen VM9424 Car Video Player
2 Suggested Answers
SOURCE:
SOURCE: I don´t known how watch videos on SD card - Jensen vm9512. Format
yes you can watch video
I alredy did it in my jensen
all you have to do is:
xvid avi
video codec: mpeg4
video bit rate: 887kbits/s
video size: 576x320
aspect ratio: 16:9
set this setting in total vide converter
do the convertion and that's.
Posted on Aug 08, 2009
Vm9424 unit will not power on pressed reset button and it beeps and lights around function buttons come on and go back off fan comes on for about 10 seconds and turns off checked power ground fuses.is...
Hello lumberjack623,
When the jensen starts acting this way, it is simply a power problem. The device is not receiving power from the main source. The battery is weak and need to be charged before the unit can turn on once again. The battery power is too low to turn the unit on.
Try to check the power source or the connection to the power source. It is not charging the players battery. You need to have the connection port replaced. Also the power connection needs be checked.
The battery is simply weak that is why it goes right off when it comes on.
Hope this was helpful to you. All the best Elect_Comp
Sep 06, 2011 | Jensen VM9424 Car Video Player
I have a new vm9424 that was put into a 2005 h2. Main problem is i can reset the time, but once i drive it for more tha a mile the clock keeps resetting its slef to a /12 hour later than it is.. nor a...
CHECK THE CLOCK BUTTON SOUNDS LIKE ITS STUCK. IF ITS A TOUCH FACE SET THE TIME THEN MAKE SURE YOU GET OUT OF THAT PROGRAM AND GO SOME WHERE ELSE IN THE SYS. IF THAT DONT WORK SEND IT IN FOR WARRANTY REPAIR,
May 26, 2011 | Jensen VM9424 Car Video Player
My Jensen VW9424 Navi unit doesn't keep the correct time. The unit displayed a time 30 minutes ahead of the correct time after installation. Several attempts have been made to set the correct time;...
you have to turn off the gps time there is a setting in the menu that you turn off navigation sync or something like that. Go to setup and nav time. It is whatever setting has to do with navigation time
May 25, 2011 | Jensen VM9424 Car Video Player
WHERE CAN I GET A MANUAL TO INSTALL A BLUETOOTH SISTEM MODEL VM9424 TO MY FORD EXPLORER
Hello there,
Here is a link to the PDF file that you need
http://audiovox2.info/docs/jensen/man/VM9424_DOC_IM.PDF
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Jensen GPS
xvid avi
video codec: mpeg4
video size: 576x320
aspect ratio: 16:9
Mar 19, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9424 Car Video Player Logo
46 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
