Are you sure 860 is the error and not the model no? Here are the common Hotpoint error codes:
F2 Motor jammed or tacho off
F3 NTC thermistor shorted or open circuit
The thermistor is the temperature sensor that reads the temperature of the water, in many Hotpoint and Indesit washing machines this is located either in or just beside the water heating element. The thermistor is a Negative Temperature Coefficient type so the resistance of the thermistor will fall as the temperature increases, this can be easily tested with a simple multimeter and a cup of warm water.
F4 Pressure switch jammed empty
The pressure switch is the sensor that is attached to a pipe unsurprisingly called a pressure switch hose that is very thin, about 10mm or so in diameter, that will come off either the sump hose (the one from the bottom of the washing machine tub that runs to the drain pump) or from the drain pump housing. Also check that this thing hose is clear.
F5 Pressure Switch jammed on full
As above for fault code F4.
Also in the first instance check the drain pump filter for any blockage or, if there isn't a drain pump filter fitted the pump will need to be removed and inspected for any blockages.
F6 Not Used
Error codes that are not used do sometimes appear and, in most cases, it will indicate some for of failure with the electronics. If you do see this fault code then it's probably not going to be good news.
F7 Heater relay stuck
This code is pointing towards some for of failure in the heating circuit, that is to say, that it could be anything on the heater circuit and you must therefore check all components with a multimeter and make sure that they are all okay. The heater will be a simple circuit that you either have or, it will be open circuit the actual resistance reading is not of any great concern.
To go any further with this you really will need some more specialised test equipment and the knowledge of how to use it, it is therefore outside the bounds of what we consider to be a reasonable DIY repair.
F8 Heater relay stuck
As with fault code F7, check the heating circuit and in this instance, the pressure switch for any failure.
F9 Setup error
This one is bad news, it basically means that the electronics either need reprogrammed or very possibly replaced, This is not a cheap repair to do and not one that is recommended for DIY repairs.
F10 Pressure switch
This error code would point towards a failure with the pressure system or a failure to read the pressure sensor correctly.
F11 Pump
This is a failure to drain or to detect the presence of the drain pump in the washing machine. Check the pump for blockages or any obvious signs of damage, does the pump impeller turn freely, are the windings of the drain pump open circuit? Again if the winding coils of pump motor are open circuit then it will need to be replaced but if the circuit is complete then it should be okay and run, the actual resistance is not really required.
F12 No comms between cards
This is either a cable fault as indicated or a failure in one or two of the electronic control cards.
F13 High dryer temperature
What this is saying is, basically, that there is probably either some form of blockage in the dryer side of a washer dryer or, there is one of the components of the dryer assembly faulty.
F14 Dryer not heating
Again, a very ambiguous error code. Check the components indicates and ensure that they are working as they should.
F15 Dryer element relay
Also check the dryer element and thermostats for good measure.
F16 Not used
As fault code F6.
F17 Door lock
This could be a simple case of the door not closing correctly as well as a door lock fault, Check that the door of the washing machine is closing and engaging correctly.
F18 Comms Error on 3 phase motor
F1Motor triac short
Check motor and module connections
This fault is usually associated with either a failure of the electronics to "see" the motor in some way or that the motor itself is faulty and therefore the error is reported.
As with the fault above this is a motor related problem and the electronics are correctly reporting that failure. If the motor is proved to be good then it is possible that a fault on the main circuit board has occurred.
Check NTC thermistor, connections and module connections
Check pressure switch, wiring and module connections
Possible pump block, check pump etc. for blockage
Check heater wiring and module connections
Check pressure connections for heater, wiring and module connections
Incorrect or faulty EEPROM fitted, check EEPROM
Check pump connections and module connections
Check module connections
Check dryer motor, dryer NTC thermistor and connections possible restricted airflow
Check dryer thermostat (one-shot), element and connections to module, fan motor, valve
Check door lock, door and connections
Replace power board
