I would like to knoww about fender serial number LO-324165
Http://intl.fender.com/en-CA/support/ Check this link and scroll down.
SOURCE: trying to find manufacture year for fender dg5
has electronic tubes? the first two sn: digits is year made as 96xxxxxx is year 1996.
SOURCE: I have a Fender Telecaster guitar and a Crate amp that cuts out i
The next time it stops, unplug the cable from the guitar and touch the tip of the connector with your finger. If the amp hums, then the amp is still working and the problem is in the guitar. If there is no hum from doing this, then the amp has am intermittent.
Try this before it fails to see what to expect in the way of the hum from this test.
Common problems with the amp are OFTEN with a broken input connector or bad switch on the preamp output jack if it has one.
There are MANY other things and without troubleshooting it is hard to steer you to a fix.
SOURCE: i want to know what year made my fender guitar
Here is the link you need:http://www.jedistar.com/jedistar_vintage_guitar_dating_fender.htm If this helps, please rate me.
It could be dirty interupt contacts on the jack you are plugging into. Spray some conct cleaner from the back side and plug and unplug a few times to see if that clears it up. Also spraying the controls and switches- make sure you get the spray stream into the switch or potentiometer to get on the contacts to disolve grime.
Other potential sources are poorly soldered connections on the amp chassis- litterally anywhere. Reflowing all solder connections would likely remedy the problem.
Also make sure the nuts that retain the jacks to the amp chassis are snug and will not move.
