Need to do tub clean and instructions say I need oxygenated bleach for my 13kg 2013 LG top loader but can't find it in the shops here in South Africa. Is there an alternative?
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
SOURCE: Where can I buy a
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you may be presented with a number of local sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
SOURCE: Weve got a 13Kg top loader and it is not spinning
truobleshoot the machine program panel or call ur technician
