Connection
There are 2 ways to have an EQ in the system. If the mixer (1204) has inserts for the mains, you can use a set of insert cables to connect the EQ. If not, connect the Output of the mixer to the Input of the EQ and the Output of the EQ to the Input of the Amp.
The insert cables will allow you to electrically connect the EQ as described above only using a single set of cables. These cables are 1/4" balanced or stereo at one end (Tip-Ring-Sleeve) and dual XLR at the other. You will need 2 insert cables, one for right and one for left.
Hope this helps,
dan
