I was changing oil pump as I open timing gear case I found that all timing gear are crushed/damaged and the thrust plate and key is broken.I found broken bushes on sump.what could be the cause?
Loss Of Oil Pressure is usually the Cause.Looks like its time for a new Engine, But You're Problem was Probably caused By the Wrong oil and Or No oil Pressure.I've had People tell Me they Used a Heaver Oil for summer time and A lighter Weight oil for winter, This Used to be an ok Practice in the Past, with Solid Steel Blocks But was NEVER Recommended Ever, Since the Change in oil weights eventually Breaks down the he Bearings from the differences in Viscosity in oils,But With the Newer and lighter Aluminum Blocks, Every thing Affects the Performance of the integral Parts IE:Bushings, Bearings, Seats ,Lock tabs, Shear pins/Keys .
So Now You need a new Engine Sorry
SOURCE: ford f450 6.4-high pressure fuel pump failure
I would like to clarify, and somewhat solve this issue. First of all the dealer is right about the regen. If the truck is going into regen and did not finish, then it will do the regen again and again and this excessive regen will cause fuel in the oil. Unfortunatly Ford did not add a parked Regen switch (too complicated for some users) so you will have to drive untill the regen light goes out. I know it's inconventant but that's part of the hassel you need to go through because Al Gore invented the internet and then warned us all about global warming. Anyway there are some other causes including porous cylander heads (this will show up in low mileage vehicles only), HP Fuel pumps, fuel sensors, injectors, lines, etc. etc. Since you both seem to have low mileage ask the Ford Dealer about the porous cyl heads and watch his face go blank. Is smoke comes out of his ears make sure his DPF isn't clogged and ask him if he needs to Regen. then tell him he has to run 30 mintues weither he likes it or not or he will get fuel in his oil. By the way you may also need to ask about an updated ECM reflash which could help this issue. Have a nice day.
SOURCE: 1995 galant broken balance shaft belt
You sould replace the belt along with the timing belt. If it gets caught in the timing belt you will have MAJOR EGINE DAMAGE!
SOURCE: harmonic balancer wobble will it cause any more
yes besides causing a vibration while driving and possible throwing belts the balancer out of balance can cause problems with the lower end crankshaft such as seal leaks ,bearings and if breaks off or apart can cause damage to engine and body
SOURCE: mazda b 2500 how to set timing when the timing belt has broken in
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK on the following LINK. It has the Timing Belt and Mark(s) Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/1998/make/mazda/model/b2500/1998_mazda_b2500_timing_belt_diagram_marks.htm
SOURCE: 2001 Dodge Durango--Transfer Case Broke Cause ?????
possible i suppose
Testimonial: "Thanks for your opinion,Chrysler even said it was possible,that all of it connects to each other and one tell's the other one how to fuction, "
Fig. Fig. 19: Holding the rear timing balancer shaft-4-cylinder Odyssey
Fig. Fig. 20: Aligning the front timing balancer shaft-4-cylinder Odyssey
