Nikon D80 Digital Camera with 18-135mm Lens Logo
A
Anonymous Posted on May 04, 2014
When I turn on My nikon d80 with 55-300lense it shows an error
Ernest Taliaferro
Level 2:
Novelist:
Scholar:
  • Nikon Expert 197 Answers
  • Posted on Jul 28, 2014
Ernest Taliaferro
Nikon Expert
Level 2:
Novelist:
Scholar:
Answers
197
Questions
0
Helped
65863
Points
278
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
2helpful
When I turn my camera on. The lens moves out, then back in. Then it shows me lens error. I have a Nikon coolpix S3000
Here are quite a few troubleshooting steps for the infamous "lens error". Recommend following them in sequence exactly as shown:
There is an error showing "Error Code 6a80" tells
Hello
I would rather just navigate you to this link with the illustrations.
Click HERE.
Please feel free to let me know if you need any further assistance.
Kind regards
Lock123
There is an error code FE E which will not allow pics to be taken. It shows up when the camera is turned on and when look thru the view finder, it also shows in the bottom.
This is a Nikon SLR error for something is broken. Here is a link. http://www.loeki.tv/log/archives/85-FEE-error-on-Nikon-DSLR-fixed.html
May 02, 2010 • Cameras
2helpful
My nikon coolpix s210 shows lens error
Hey digi_5
This is a common problem with Nikon and it isn't covered under warranty since Nikon sees it as an error resulting from usage. Apparently, the Coolpix is pretty delicate and any slight bump can cause a lens error.
Some people have tried gently twisting the camera lens back into place or gently tapping/bumping the side of camera.
If neither of those work, I'd say try getting the camera repaired professionally - if it isn't covered by Nikon, they'll charge you heavily. I've used Teleplan Camera Repair before and they're cheap compared to other places.
I've heard that once the camera is fixed, turn it to the Playback mode before turning it off - it apparently helps avoid the problem altogether.
2helpful
Lens error won't go away
Sadly, the camera needs service.
2answers
Coolpix nikon s51 showing on screen ' lens error'
This is a pretty common problem, especially on the coolpix range. Basically it means the lens has had some issue while driving in or out of the camera body, in some cases a simple tap on the camera side(not recommended by me) can fix the problem, in others you will have to send the camera to nikon to fix it but it will fall outside of warranty as its not considered a normal camera error.
2helpful
2answers
LENS ERROR
My Nikon L14 Camera Is Showing Up Lens Error
Can Someone Please Help Me.
Lens error
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon-authorized service representative."
2answers
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
