The Nikon D-90 users manual says on page 256 that the ERR message indicates a camera malfunction and that it can be cleared by releasing the shutter.
I've found on my D-90 that the only way I can get the shutter to release is my turning the camera off. When I turn it back on the ERR message is gone and the camera functions as it should.
Occasionally, I have had to remove and reinstall the battery to make the camera turn off but this happens only rarely.
The users manual says if the condition occurs frequently or persists that you should contact a Nikon authorized repair center. I suggest that you contact Nikon tech support at www.nikon.com to see what they suggest. I think this information would apply to the D-80 as well.
SOURCE: pop up flash nikon D80
There is a small hex screw on the underside of the flash pop up... next to the latch. I gave it a half turn and presto... fixed...
SOURCE: Nikon D80 flashing 'err' and 'off'
Usually you get this kind of problem in variations of temperature. Humidity means moisture and that isn't good. The Nikon D80 body was not built for harsh conditions. Nikon define that any use above 85% humidity, or use near 100 degrees, plus any use involving moisture of any kind? including hands/body (camera resting on a shirt while walking) is bad. So it's not robust by any stretch of the imagination. The model is not made with environmental seals, like pro models. I guess they aimed this model at enthusiastic amateurs and didn't see the need. Trouble is this model can, in the right hands take pro-quality shots. I use two, like you, but I saw this problem coming and I never wear them suspended from the neck and put them away when they are not in use with plenty of silica gel in my bag. I shoot racing and I REALLY sweat! If you have the lcd screen up against you on a hot day it intensifies the heat. The problem is likely to be moisture on the PCB board, which causes corrosion to the board. If you've ever done gym class and the windows have steamed up it's the same thing. It's just means the temperature inside the camera is way too hot. Anything electrical causes heat, so the temperature on the inside is gonna be way hotter. If it is cooler on the outside it causes condensation. If you have dried it out and you still have problems it's gonna need fixing at Nikon. The bottom line is that it's fragile; that is alluded to in the manual. It sounds improbable but I can assure you that Nikon will tell you the same. It's not the sweat on your hands that is causing the moisture..highly unlikely. Hope that helps.
SOURCE: Nikon D80 won't take photos!
The F-- error means that the camera does not think that you have a later AF type lens attached.
If you are using the 18-135mm then the camera is not properly connecting to the lens.
To test this, press the lens release button on the camera and slightly turn the lens as if you are going to release it then turn it back to lock.
This may fix the problem.
If not you can try remounting the lens a few times and if that doesn't work you could clean the lens contacts.
The contacts are the metal studs on the back end of the lens, the bit that goes into the camera.
Sorry if that is too obvious.
If you have an early lens it must be set to the smallest aperture using the ring around the lens.
This will be 22 or 32.
Then lock it using the little lock near the ring.
SOURCE: nikon d80 problem (err flashing with r09 in the lcd display)
yupz.... r 09,, it was not an error. it mean a value of the camera memory buffer . a memory buffer is temporary memory before your captured images stored to memory card.
The 'Err' error message, mean your camera is malfunction. and all you have to do is contact nikon service center
