If you are trying to use another manufactures remote to control your Onkyo receiver they are the ones who are responsible for programming the Hexadecimal codes into their remotes. We do not have codes for any other manufactures remotes. You may want to try the following website for codes www.remotes.com or http://www.remotecodelist.com for any codes to program your remote. As we do not have the remote controller codes for non-Onkyo controllers- you can try the generic remote controller code: 62503 or 52503.
SOURCE: Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
SOURCE: cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
SOURCE: Onkyo tx-sr605 remote codes
The Remote Code for the Onkyo TX-SR605 that will both turn it on and also turn it off is: 1789.
