SOURCE: Homelite Trimmer Pull Start Cord
The part no. for the Spring and container is A98773A. You can Google the PN and find many sources. Expect to pay between $10.00 to $15.00. I like m-and-d.com If they have it in stock you will normally get it in 3 to 4 days.
SOURCE: pull cord stays out, won't retract. I took apart
the end of the spring may be broking you can fix it by taking it out and heat it with a small fire until it is red hot and bend it
SOURCE: Pull Rope Broke... How do I replace it and still have it retract?
with the cover in your hand pull the cord out with a pair of needle nose pliers or a little screw driver and where the cord go through the case and before the wheel. pull 5 to 10 inches out and wrap the cord around the wheel turning the wheel but not winding the cord on., do 3 or 4 wraps then pull the handle to get all the cord out and let it retract. if not enough rewind just repeat with 2 wraps
SOURCE: homelite weedeater pull cord wont retract once ive
you will need to remove starter cover & boom assy ,
sounds like either the rewind spring is broken or the pulley has split at the base of pulley or the starter pawls are bent / jamming , check that the centre pivot if this unit uses this type is not binding , pulley should be free , check the pulley is not damaged ?
either way once cover is off you should be able to see the problem
check the lugs that secure the pulley to the cover if unit has 3 lugs that secure to the cover ?
replacement parts should be available reassemble and test
cheers hope it helps paul
SOURCE: Featherlite/Mightylite 26ss pull cord will not
They don't spin with the engine, however pinning them together isn't your fix. The spring has to be fixed at both ends, sounds like one end or the other is comming out of its keeper. Check if the ends are broken
