SOURCE: Dir 628 - Dropping the internet connection when idle for a while
it might not be pointing to the correct DNS....check what your DNS is using command prompt.....the command is either "netstat" or "ipconfig /all"
SOURCE: how do i add the printer the dlink dir 628 router
The DIR-628 does support a USB printer. You need to download the appropriate shareport version from dlink http://www.dlink.ca/products/?pid=DIR-628&tab=3.firmware
If the printer drivers are already installed on your PC you should be ready to go.
SOURCE: My D-Link DIR-628 Router won't turn on!!
pls check if your using the correct power adapter, if you use the wrong power adapter, it might not turn on.
SOURCE: Dlink DIR-625 Doesnt work. Power light blinks when plugged in
hi.. all,
i am facing the same issue.. my new DIR-615 , when plugged with power cord ... make the power led blink continuously... and hence so, no network is accessible neither wifi works in simple terms noting works, no combination of power cord with network cable with computer works.
i have even tried resetting using the reset button.. but still the power button keeps blinking.
and yes it was working in past, its a brand new product(3 months old).
Please help and its urgent..
thanks a lot for your help..
Regards
Dharmendra
SOURCE: dir-300 dlink router asking to reset to factory after installatio
there's an easy way to reset your router back to its factory setting... inspect the physical appearance of your router... there should be s small hole.... inside that small hole is a reset button
How to reset? ..... while the router is on...Using a small pointing object, much better if you use a paper clip..... insert the paper clip to the hole... press and hold the reset button for 10 seconds...
That's it your router will restart itself and the settings is back to its factory settings...
Hope that help you..
Much appreciated if you rate this help... thanks
