Question about Generac 13,000 Watt / 13,000 Watt Home Standby Generator
Unit shuts down from overspeed fault unit has 35 hours total run time never ran more than 2 hours 45 minutes rest is excerise time . is this problem with the 15 kw common ?
  • skydiver917 Jun 22, 2009
    unit is less than 3 years old
    President:
  • 1,730 Answers
The engine throttle control is out of adjustment. It needs to be set based on the generator frequency
(60 Hz).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 27, 2009
SOURCE:
Overspeed fault Possible damage from over voltage to refers and other items. 15kw propane Watchdog unit. How can I set unit so it puts out correct voltage and doesn't shut down from overspeed?
hi
not knowing the age of your unit ( and not been very familiar with your watchdog ) i can confirm that the not so old ones are platically sealed unit in which case a replacement one is needed . if the older type them you are going to need an volts / amp meter and then realic unless you know basic electric law you have no choice but to let an electrical engineer to look at it
Jan 08, 2018 | Electrical Supplies
Generac over-speed fault
check your frequency of the ac, if this is high, then adjust the rpms.
If that is fine and it is shutting down, check overspeed adjustment on control board if it has it.
Jul 16, 2017 | Generac Electrical Supplies
=1995 volvo road tractor symptom [engine shuts down] code; active,engin e, intake,air,tmp,short,+v
I recently came across a similar situation in a isuzu that took some time to diagnose. What if eventually turned out to be one injector had an intermittent failure and it too out 2 other injectors and the engine shut down. If the vehicle sat for 1/2 hour it restarted and ran again for sometimes days before the fault again appeared. It was tracked down by running the truck on a chassis dyno under load and when the fault appeared each injector was disconnected until the faulty one was revealed. If these symptoms parallel yours I suggest you point the mechanic in that direction .
Mar 11, 2013 | Cars & Trucks
Generac Guardian 12 KW Model 04456-2 shuts down on overspeed in cold weather
Leigh,
See my 5/22/12 comments on my "overspeed fault" problem resolution [Generac 43903 standby Generator overspeed indicator on starting] . If it only runs for a few seconds and then quits, you may have a similar condition to the one my unit had. A good technician should be able to diagnose the problem and determine if you have a similar failure to the one I had, or one of the other causes suggested by RSG000.
Jan 20, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
My 18RESL Kohler Propane Generator ran for 8.5 hours and shut down for overspeed. later it started up again and shut down for under frequency. Now it won't even turn over. Where do I start. I checked...
You have to reset it because it locked out on on under frequency. Just pullout the fuse on the control panel and then reinstall it a couple of seconds later. Now it will reset the fault codes. Hope that helps.
Dec 02, 2010 | Kohler 12 kW Emergency Power System -...
Heating up, shuts off, Shutting off going about an 1 hour trip. hearing small noise in front of engine. Seams to be running hot. service techs put it on dyna but no results. Shut off again next trip. ran...
Had a simuliar problem, Bike would have a total shutdown a High Temps/Low Speeds/High RPMs. Everything would reset itself after appox 2 minutes. Everything would shutdown Electric and engine.
2 Harley dealers spent 75 hours diagnosing it, dealer could not reproduce it. Last repair was to replace battery cables. Seems to have fixed it. Have ridden 15oo miles since repair. Problem reacurred once last time I rode. Again complete shutdown bike restored after 2 minutes. Did not happen again the rest of the day over 200 miles
Aug 30, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Own 2005 27.5' Wildwood Trailer with a Dometic a/c ducted unit. Last few times out it freezes up initially first few times (pocked circuit breaker once then I turned it off after few minutes second time)....
Don't block off any ceiling ducts and see what happens. If you've closed off any forced air ducts, the unit will freeze up, if too many are closed off. Also, if you shut unit off (compressor) give it 5 or 10 minutes before you turn it back on.
May 21, 2010 | Dometic Rooftop RV Air Conditioner
Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
1995 Ford Thuderbird
Depending on which type of carburetta this car has, it may be that the rubber diaphram has a tiny pinprick of a hole in it. This will affect the vacumn and the fuel control. An easy way to test this is to allow the car to rest without the engine running for a few minutes, start the engine an increase the power whilst at a standstill and see how long it takes before the engine shuts down, then let it rest again for a few minutes, start the engine and let it run just on tick over, if it carries on running for a much longer period than before then you may have the answer.
Hope this helps Bomber667
Dec 01, 2008 | 2006 Ford Thunderbird
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Generac 13,000 Watt  / 13,000 Watt  Home Standby Generator Logo
1,534 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
Bob Janelli
Level 1 Expert
Craig Butler
Craig Butler
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
