see this causes and fix it. God bless you
Incoming Power Problem
If the washer won't start check to see if
there is power at the electrical outlet which the washer is plugged
into. Plug a lamp or radio into the outlet to check it. If the outlet is
dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure
there is power to the electrical outlet for the home. If that is OK, the
power cord itself might be defective. This is rare. You can check the
power cord with an Ohm meter for continuity.
User Control and Display Board
If the washer won't start, the user control
and display board may be defective. Check for power to the washer first.
Timer
If the washer won't start the timer might be
defective. This part is often misdiagnosed, check other components
before replacing this timer.
Line Fuse
If the washer won't start the line fuse might have blown.
Thermal Fuse
If the washer won't start the thermal fuse
may have blown. It can be tested for continuity. Watch our fuse testing
video for more information.
Line Fuse and Holder
have blown, or the line fuse holder might be damaged and need to be
replaced.
Main Control Board
If the washer won't start the main control
board might be defective. This is not common. Check other parts and
causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch
assembly might be defective. This is a very common problem. The lid
switch assembly can fail either mechanically or electrically. Test any
electrical switches with an Ohm meter for continuity. The switches
should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock
assembly should be checked. The door lock can fail either mechanically
or electrically. Test any switches on the door lock with an Ohm meter.
The switches should have continuity according to their design.
