Question about NetGear DG834G Router
Router netgear wndr3400
Low speed
SOURCE:
sandrew
  • 2961 Answers
SOURCE: netgear router dg834gt
Have look in the router settings for the actual internet connection speeds, as these are a more true reading than the speed check as the speeds can vary at different times of the day and 2 or 3 speed checks can bring different results. your actual connection speed that is showing in the routers settings is the connection you are getting from your ISP. If you are with BT they usually recommend using their latest routers, why i'm not sure, as the only thing i have noted is that the MTU is set at 1500 (Maximum Transmition Units)and in other routers the MTU is automatically set at 1493, so look for the MTU setting and up it if necassary, but not above 1500, also double check all the settings, even put the bt router back in and see if speeds improve, if, you know the BT router is set up purposly for faster connection speeds. Also try checking your speed at a speed test site at a quieter time of day, you will also see different speed check sites give you different speed results.
Posted on Jun 18, 2007
charlesharun
  • 174 Answers
SOURCE: NetGear WNDR3400 N600 router set up fine, but it's
The wireless router has capacity to over perform only situation with the device connectoins to your computer are receiving signals from more than one network. You are allowing several signals to access the computer. Establish one network pass at a time. a stronger once should be chosen and the device would perfrom to capacity. The network setup need to be reconfigured
Posted on Dec 03, 2010
SOURCE: my netgear wndr3400 wireless router
change the channel selection in the wireless settings from auto to a any one of the channels on the drop down list. I actually did it by trial and error until the i found a channel that works. Also if you have the router on the ground floor of a multi floor home the signal range is lousy, move it to the second floor and keep it away from places where they are too many electrical devices close by maintain at least 6feet of distance from televisions and speakers and the range will be excellent
Posted on Feb 21, 2011
  • 22 Answers
SOURCE: Well I think the router
just turn your fire wall off then, try it ,then put your fire wall back on med.
Posted on Feb 23, 2011
Cylon13
  • 55 Answers
SOURCE: The region settings of my
Download the firmware update or same version from the netgear website, try to download a version for asia there.
Posted on Mar 14, 2011
Firmware update 5102g
The firmware WNDR3400 Firmware Version 1.0.0.52 and instructions are here.
NETGEAR Support Answer WNDR3400 Firmware Version 1 0 0 52
Mar 08, 2014 | NetGear WNDR3400 N600 Wireless Dual Band...
Wndr3400 blinking green power light
According to the owner manual, a blinking green power light on the WNDR3400 indicates corrupt firmware. You can supposedly use the restore CD that came with the router to attempt a firmware recovery.
I pulled the following from the owner manual regarding firmware recovery, which you can find online at ftp://downloads.netgear.com/files/WNDR3400_SM_23MAR2010.pdf. Page 35 has this procedure
1. Make sure that your PC is connected to your router and the router is powered on.
2. Insert the Resource CD that came with your router into your PC. The CD automatically starts and detects the language you are using on your PC. Select a different language option, if you prefer. If the CD does not automatically start, browse the CD and double-click on .
3. Click Supporting Software, then Netgear Firmware Recovery Utility, and follow the prompts for the recovery process.
4. After firmware recovery is complete, follow the prompts to restore your configuration
Sep 12, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Iam not able to change region my NETGEAR WNDR3400 Router to india(asia)
the router may not be designed for that regian you may need to purchase a new router
Jun 05, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Why is my wndr3400 netgear router reducing my internet speed?
one way to find out is run this site on the router then run it again without it and see if your speeds change CLICK HERE I use these guys alot.
May 29, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I want to know if the WN111 will be compatible to my new WNDR3400 router
Well, I know this may be solved by now (Hope so anyway, right???) but YES IT DOES !! I just set up our new WNDR3400 this evening and my son has 240 Mbps through a Netgear WN111 out in the garage (approx. 75 ft. away...)
Jan 20, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
NetGear DG834G Router Logo
19 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
