Red means TV on standby. TV remote not working. Check the transmitter LED flashes by viewing remote on a digital camera or phone whilst pressing the buttons. The invisible light will flash purple viewed from the camera.
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In ______________________________________________________________________ •Headset Indicator Headset Status Red-----------------------------------------------Charging (battery level less than 50% charge) Yellow-------------------------------------------Charging (battery level more than 50% charge) Green--------------------------------------------Charging complete
---------------------------------------------------------------------- ====================================================================== ====================================================================== ====================================================================== ---------------------------------------------------------------------- With No Charger Plugged In __________________________
Headset Indicator Headset Status ______________________________________________________________________ Off ---------------------------------------------Power off Three blue flashes------------------------Powering on/off Steady blue --------------------------------Pairing/connect mode Rapid blue/purple flashes -------------Connection successful Quick blue flash --------------------------Incoming/outgoing call Slow blue pulse --------------------------Connected (on a call) Slow blue flash ---------------------------Standby (not on a call) Slow red flash ----------------------------Idle (not connected to phone) Slow purple pulse -----------------------Connected call muted Steady red ---------------------------------Attempting to connect Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on ----------------------------------------------------------------------
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
to check if it is the remote or the sensing board if u have a camera on your phone u can point the remote into the camera and see if there is a purple light that flashes on the screen or not. if u can see a flash the remote is working fine and it is the board. please note that this dose not seem to work with iphones
it depends on what stick you have, usually you have 2 lights, one will stay on constantly indicating power, the other will be data transfer (this will flash wildly whenever data is read or written), good luck
1 red light means general hardware failureand it is pretty much the same as 3 red lights but it is has a slightly different problem. if you are under warranty send it of to microsoft. they will repair it for free. if not buy a new warranty for 60 dollars.
The purple (majenta) light usually means it is in pairing mode. Is it possible that the button is stuck pressed in??
PUT HEADSET IN PAIRING MODE
1.Ensure the headset is turned off (indicator light not blinking and headset boom is closed) 2.Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta 3.Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the headset boom, repeat steps 1 through 3
