Question about Lenovo Computers & Internet
How do I retire a Signal out of Range error message?
My Lenovo IdeaCEnter PC is running Windows 7 Pro & the Monitor is an HP2311x set for 1920 X 1080 resolution with color depth set to 32 bit at 60Hz refresh rate using a VGA connection; the monitor is manually set to make VGA the default input port; using the Intel Graphics and Media Control Panel (also the native Lenovo Display Control Panel settings when this bug would not go away. The input signal out of range does not retire. Using the popup widow one gets when outside mouse button clicking on the Desktop/Graphic Options/Balloon Notification/Optimal Resolution/Disable checked option STILL DOES Not turn off the "Input Signal Out of Range Popup window error message." Rebooting after each reset to 1920 X 1080 - 60Hz does not retire the "Input Signal Out of Range Popup window error message."
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 95 Answers
Go into HP screen menu and turn off the display notification
Posted on Jun 05, 2014
4 Suggested Answers
6ya staff
SOURCE:
Ezrahite
Rofel Lantican
  • 2632 Answers
SOURCE: Hi, Iam trying to set up a 3d system. Iam using an
Welcome to Fixya.
Acer h5360 1280x720 supports Bluray 3D see Documentation. However the Intel 945 Express Chipset Display dont have Pixel Shader 3.0 recommended for optimized visual performance. And like other HD movies you need to use a high definition cables such as HDMI or Component Cables.
Thanks for using Fixya.
Posted on Feb 24, 2011
Azrael SRL
  • 11800 Answers
SOURCE: My monitor gives 16-bit color
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Posted on Aug 02, 2011
hardrockr
hardrockr
  • 3 Answers
SOURCE: The input signal out of range on screen persists in spite of all monitor and PC video settings being correct.
Have you tried uninstalling the graphics driver entirely and then rebooting? Could be a corrupted driver.
Posted on May 04, 2014
May 04, 2014 | Lenovo Computers & Internet
Tip
"Aero features are'nt running in window's 7"
Solution: Check that your computer meets the minimum hardware requirements for running Aero:
1-gigahertz (GHz) 32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) of random access memory (RAM)
128-megabyte (MB) graphics card
Aero also requires a DirectX 9 class graphics processor that supports a Windows Display Driver Model Driver, Pixel Shader 2.0 in hardware, and 32 bits per pixel.
For best results, you might also want to follow these graphics processor recommendations:
64 MB of graphics memory to support a single monitor with a resolution that is less than 1,310,720 pixels (for example, a 17–inch flat panel LCD monitor that has a 1280 × 1024 resolution)
128 MB of graphics memory to support a single monitor with a resolution from 1,310,720 to 2,304,000 pixels (for example, a 21.1–inch flat panel LCD monitor that has up to a 1600 × 1200 resolution)
256 MB of graphics memory to support a single monitor with a resolution greater than 2,304,000 pixels (for example, a 30–inch wide-screen flat panel LCD monitor that has up to a 2560 × 1600 resolution)
To turn on window frame transparency, the color scheme must first be set to Windows Aero.
1.Open Personalization by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
2.Click Window Color and Appearance.
3.Select the Enable transparency check box.
To change the color scheme to Windows Aero
1.Open Appearance Settings by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Window Color and Appearance. If the Appearance Settings dialog box is not displayed, at the bottom of the page, click Open classic appearance properties.
2.In the Color scheme list, click Windows Aero, and then click OK.
Check that your theme is an aero theme and not a normal theme. Themes are available in normal and aero and can be confusing. Set your theme as an aero theme and you should get the aero window working.
These steps will help us to have AERO running.
Thank's and Regard's:
Pcs365.8
on Jul 13, 2010 | Computers & Internet
Www helpouts google com
Try resetting your graphic to default and reset the monitor to factory default.
May 04, 2014 | Televison & Video
Monitor running vista 32 bit will not work with windows 7 64 bit
Before switching display check resolutions on both the PC's they should be same or else change the latter PC's dis[lay as per the first one
Apr 04, 2013 | Dell Computers & Internet
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
I have an LT Series Gateway Netbook. I am trying to connect to a Sony VPL-AW15. I am using a Sony STR-K7000 A/V receiver. The projector is giving the error message "Frequency out of range". I have...
HEy try changing the refresh rate
1. Right click on a empty space on the desktop and click on Screen Resolution. (See screenshot below)
2. Select the monitor Display you want to change the screen refresh rate for. (See screenshot below step 3)
NOTE: You will only be able to select a different display if you have more than one monitor connected.
3. Click on the Advanced settings link. (See screenshot below)
4. To Change Only the Screen Refresh Rate -
A) Click on the Monitor tab. (See screenshot below step 4C)
B) Select an available Screen refesh rate from the drop down menu.
WARNING: It is recommended to leave the Hide modes that this monitor cannot display box checked to prevent possible damage to your monitor.
C) Click on OK. 143d1229784117t-screen-refresh-rate-display-settings-monitor_settings.jpg
D) Go to step 6.
5. To Select from a List of All Display Modes -
A) Click on the Adapter tab, and on the List All Modes button. (See screenshot below) 7331d1238960189t-screen-refresh-rate-display-settings-adapter1.jpg
B) Select the display mode with the screen resolution, color depth, and screen refresh rate that you want to use, and click on OK. (See screenshot below)
NOTE: It is recommended to use a native screen resolution with a True Color (32-bit) color depth. 7332d1238960189t-screen-refresh-rate-display-settings-adapter2.jpg
C) Click on OK. (See screenshot below step 5A)
6. Click on Yes to confirm the screen refresh rate change. (See screenshot below)
7. Click on OK. (See screenshot below step 3)
Apr 28, 2010 | Lenovo IdeaPad S10e Netbook
Red stripes on the screen when choosing a 1280 x 1024 resolution and 32-bit color depth.
640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, ... With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), ... A black and white monitor uses 1-bit color depth (2 to the power of 1): ... 5 bits for red, and 6 bits for green, giving 32 different intensities for ...
www.thescreamonline.com/technology/.../monitor_res.html
Dec 06, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Toshiba Windows Vista resolution problem
Depending on the version of A100 you have, 1280X800 may be the max resolution for your graphics card. Read the user manual for your specific model to see what the max resolution is, but usually, the video driver will lock out resolutions that your screen cannot handle.
If, for some odd reason, your screen can handle a higher resolution, try updating the video drivers.
Now to answer your other questions;
  • There is no 64 bit color mode; and if there was it would be redundant, as humans can't see that many colors.
  • 60Hz is fine and is probably the best your monitor can do.
Aug 07, 2009 | Microsoft Computers & Internet
The monitor only displays either 1920x1080 resolution with Low (8 bit) color or 800x600 with High (32 bit) color. I have uninstalled the video card and monitor drivers and reinstalled them a million...
It appears that your video card does not support that resolution and color depth. If you've installed all of the proper drivers from the manufacturer, re-check the maximum specs - sounds like you're looking for HD (1080) and the card can't deliver in full color (32 bit).
Jun 07, 2009 | Computers & Internet
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Computers & Internet Logo
183 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
