Question about Samsung SMH7159 Microwave Oven
Panasonic Microwave Turn table rotates when door is open
Have a Panasonic NN-T993SF Microwave. When the door is opened the turntable rotates All other functions operate normal
  • 5 more comments
  • Anonymous Mar 13, 2014
    Turntable will not turn
    Turn table will not turn
    roper microwave run but will not heat, turntable will not rotate either
  • Anonymous Mar 14, 2014
    Cannot use
  • Anonymous Mar 19, 2014
    should the turntable go round when microwaving
  • Anonymous Mar 20, 2014
    Works fine cooks food. Stops and beeps upon completions. Ope the door the microwave turns on again with the door open. shut the door it turns off
  • Anonymous Mar 28, 2014
    My kenmore microwave operates with the door open. Why is this happening and is it dangerous?
  • Anonymous Mar 30, 2014
    my microwave turn table does not rotate
  • Samsung Master
  • 9,174 Answers
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
  • 1 more comment
  • Gary Noland Feb 07, 2013
    The link you posted does not work
  • Gary Noland Feb 10, 2013
    The link "http://tinyurl.com/yzjozk" as posted in the solution does not work..Please correct it.
  • John Cheng
    John Cheng May 08, 2014
    I fixed it by replacing a defective door switch part number: F61415U30XN fromhttp://www.reliableparts.ca
SOURCE:
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
When started,light& turntable operate normally,but no heating by microwave. Transformer normally sounds smooth,but now makes rattle or vibrating noise,like something is loose.
Check the door safety intertlock micro switch for proper behavior. If it is faulty, the oven will think the door is open and will not turn on the magnatron.
Sep 22, 2010 | Panasonic NN-C980 Convection/Microwave...
Turntable doesn't rotate
Your turntable motor need replacement. tip upside down with dish removed and gain access to turntable motor from underneath.(remove power plug before you start working on the m/wave.) 2 screws hold the small t/table motor in place.Unscrew both and pull motor upwards. Quote the info on the motor for a replacement. I find cooking isnt effected in any wayexcept if you want to bake things like cakes. It then requires the t/table motor.
May 21, 2010 | Panasonic NN-T993SF Microwave Oven
Overheating Panasonic NN-E225M
i have seen tisquite a lot, simply try and keep open space behind and ontop and u will be ok.
Jul 05, 2009 | Panasonic NN-T993SF Microwave Oven
Panasonic - NN-T993SF 1350 watts microwave
Sorry this is something you wont fix at home I couldent even do this one.This is a nice unit depending on the cost this one I think is worth the repair bill , Good luck DFD please rate me TK U
Apr 12, 2009 | Panasonic NN-T993SF Microwave Oven
T993 - Positive Lock Switch ?
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find an authorized Panasonic servicer here. You can order Panasonic parts here.
Sep 27, 2008 | Panasonic NN-T993SF Microwave Oven
Door shut off malfunction
I have the same problem starting yesterday April 19. Have you gotten any answers.
Mar 12, 2008 | Panasonic NN-T993SF Microwave Oven
Nn t993sf
Sounds like the door switches are out of adjustment or broken.
I would take it to a shop for repair. Microwaves are almost always repaired affordably unless it is really old.
Hope ya fix it!
Feb 07, 2008 | Panasonic NN-T993SF Microwave Oven
Samsung SMH7159 Microwave Oven Logo
3,067 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Steve Allison
Steve Allison
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
