Dryers Logo
Posted on Jun 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer has hot air but takes 2-3 hours to dry clothes. What can I do?
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Jun 22, 2009
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3798941
Points
33142
This is almost always due to lint build up in the vent pipe. pull the dryer out from the wall, disconnect the vent pipe. look inside the rear of the dryer and into the pipe. remove lint that is present. go out doors and examine the vent from that end. finally remove the lint catcher in the dryer and look in there. remove any lint you see.
  • Anonymous Jun 23, 2009
    This is generally the fix for this problem. let me know how you make out.
5 Related Answers
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Mar 10, 2009
SOURCE: long time to dry clothes
The dryer has one of its rows of heaters open. Open up the dryer and check the coils behind the drum. read more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
tshot2020
Timothy Shotwell
  • 23 Answers
  • Posted on Apr 20, 2009
SOURCE: NOt drying clothes like it should
Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
Anonymous
  • 11896 Answers
  • Posted on May 22, 2009
SOURCE: Dryer taking too long to dry a load of clothes.
First thing I would do is clean from screen filter all the way out. I would clean and vacuum all the dust in the vent.
If problem still persists, I would have the heating element replaced
Anonymous
  • 10 Answers
  • Posted on Jun 02, 2009
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Anonymous
  • 1606 Answers
  • Posted on Jul 19, 2009
SOURCE: My Dryer gets hot but it takes 2 hours to dry.
Go into atic and see what the vent is made of . Home depot sells 4 inch connectors whether hose or aluminum maybe 1 foot long . They may even sell a 4" brush connected to about a 10 foot cable ( a lot of parts houses do ) . Cut the tubing or hose and feed the cable down to someone who can pull the brush down . The top portion you will have to use injinuity to clean .
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 • Dryers
My hotpoint dryer takes hours and hours to dry clothes?
clean the vents as it is an air restriction, first take off the vent house run dryer and feel for hot air, if no or little hot air then then inside of the dryer needs to be cleaned, now if you run the dryer with the hose off and it drys like it should then the vent hose needs cleaned/unrestricted. Hope this helps Tim
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
The dryer is hot but the cloths are damp after 2 hours in the dryer..its hot but the cloths are still damp?
check the air in let and out let pipe are not blocked up with fluff if the dryer cant breath there will be little hot air going through the cloths to dry them out,,,also check the "dust filters"
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 • Dryers
Dryer not drying clothes
An easy way to check dryer function is to check the airflow on the outside of your home at the exhaust the vent. While the dryer is running, and hot, put your hand near the outlet. The air coming out should be hot and forceful. If not, there is most likely an obstruction, and the whole airway should be cleaned. Keeping the airway clean and clear can dry clothes faster and save you money.
Another possibility is the blower,(fan) which can become encrusted with lint, preventing it from moving air. This is much less likely, but still a possibility.
1helpful
2answers
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
3answers
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 • Dryers
Top Dryers Experts
john h
