Do not re-set you replace the developer. If you reset the copier will think it has new developer then will set voltages according when in fact the developer is old causing image issues and codes, replace the deveploer and run required procedures CLEAR THE COUNTER FIRST
try this site for parts first
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: develop ineo 161
open then close the front door -> the display show " CHANGE DRUM ? YES/NO " -> press yes on the board
SOURCE: reset drum copier develop ineo 161
1 Press the [Utility] key three times.
“USER MANAGEMENT” appears.
2 Press the [Yes] key.
"CHANGE D/C" appears
3 Press the [Yes] key.
Your done.
