Charger will not connect
SOURCE: My Pride Hurricane PMV will not go forward or
Make sure that the manual brake release/freewheel lever is in the DRIVE position. The click indicates the brakes are being released but the motors are not kicking in. I hope this helps- good luck!
SOURCE: Pride Sundancer. Batteries will not charge. both
batterys may be to low for charger to pick them back up.Sounds like new batterys to me .dobble check that charger just in case by volt testing the neg and positive wires on one battery ,When its hooked up .then do the other to see if power is getting where its suppose to be. Your checking for volt changed .Battery charger checks out good replace batterys that should do it.
Hope I was of some help have a good day.
