SOURCE: Kodak V803
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
SOURCE: lines in images
Sent camera to Kodak whch fixed it and sent it back weeks ago. A solution almost a month after the inquiry is too late to be helpful.
SOURCE: Horizontal lines running through pictures.....Z612.
I've had sinilar problems with mine. I bought it in November of 2006 and sent it back to Kodak (under warranty) 3x before they finally agreed to replace it (with a refurbed unit). Well, that was in June of 2007 and the problem is now baaaack with the reoplacement camera (same model)... I'm requesting Kodak replace it with another model, but I'm "out of warranty" and they want me to pay them $145 to repair (which they've never been able to fix for me). So I am requesting them to replace with a different model.
SOURCE: pictures are pink with lines
The camera is a wonderful Kodak product and takes beautiful 8.5 Megapixel photographs. When you save the pictures to an SD card, you must at some point remove them digitally from the card.
Either by linking it to the USB cable and going from there to your PC, OR by removing the SD card from the camera and inserting it into an SD card slot in your computer, printer, or card reader. Occasionally the card readers such as the ones in your PC, printer, or card reader devices do not connect properly and will only transfer part of the data, resulting in pink ugly lined photographs. This problem can be fixed by using the USB cable instead of the built in card readers in your other devices.
SOURCE: P850
My lens on P850 when I turn it on goes out and then goes back in, I have change the battery, can you assist
