It sounds like the thermostat or Element is failing and causing your unit to overheat and boil. Probably time to call Bunn and see if your unit is under warrenty.
follow this steps and fix it. God bless you
Clean an iron:
Unplug the iron and make sure it is cool before cleaning.
Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
Unplug the iron.
Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
If the spray pump is accessible, remove it and check for leaks by placing the spray tube in wat
cleaner.
Unplug the iron.
tension.
follow this section troubleshooting and fix it. God bless you Clean an iron:
cleaner.
Unplug the iron.
tension.
placing the spray tube in water and squirting the pump. Clean or replace
as needed.
1) test the electronic control for defective and follow the next steps. God bless you Clean an iron:
cleaner.
Unplug the iron.
tension.
as needed.
Clean a metal soleplate:
Unplug the iron.
Use a sponge and commercial soleplate cleaner or baking soda and
water to remove dirt buildup on the soleplate. Rinse well with water and
dry. Don't use harsh abrasives or immerse an electric iron in water.
Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
if the iron use electronic control, will be a little difficult to adapt or reset .However i recommend follow this steps and fix it. God bless you Clean an iron:
cleaner.
Unplug the iron.
tension.
as needed.
Unplug the iron.
Unplug the iron.
If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
