Fisher and Paykel WA37T26G Top Load Washer Logo
A
Anonymous Posted on May 03, 2014
Diverter valve Laundry is not getting clean could it be a clogged diverter valve? Dirty laundry? Lint?
5 Related Answers
Anonymous
  • Posted on Jan 25, 2008
SOURCE: fisher paykel empties as it fills (similiar to recent entry)
I had the same problem with my Fisher and Paykel washer. I replaced the diverter valve and it seems to be working fine. (Although I have only run one load so far.) I ordered the part from Fisher and Paykel. It came in 5 days. It was under $25, and it was simple to replace. Just make sure you get all of the water out of the washer first. There is a surprising amount underneath that has the potential to cause big problems if it leaks onto the pump.
Anonymous
  • 1028 Answers
  • Posted on Jul 05, 2008
SOURCE: Fisher and Paykel Pride 5.5
sure lean washer back against wall diverter valve on bottom rear next to pump probably just clogged with lint
Jeffry's Appliance Service
  • 254 Answers
  • Posted on Jul 15, 2008
SOURCE: F & P - GWL10 - Diverter Valve issue
Sounds like you might have the drain hose too far down the stand pipe and it's siphoning, try bringing the drain hose up a little.
Anonymous
  • 145 Answers
  • Posted on Dec 15, 2008
SOURCE: fisher paykel gwl11
Hi Alan.. usually if there is a problem where the diverter valve is not sensed by the machine control, it will throw a fault code and beep and not complete the cycle. There should be a tech sheet under the control panel. Did you make sure you properly re-connected the two orange wires on your new diverter valve?
I certainly have encountered several over the years where the control stops puting voltage to the diverter in recirculate mode.
If you want to be able to use all the cycles on the machine, then you need a new control board. That is part #420094USP and can be purchased from Fisher Paykel Parts direct;
http://fisherpaykelparts.net/index.php?categoryid=111&productid=26
If you need to do laundry in the meantime, use the PERMA PRESS wash cycle, it should work for you, as that cycle does not use the diverter valve.
Also inspect your water pump and make sure it isnot wet or leaky, as this can cause the machine control to either short out altogether or lose functionality on some cycls such as you are experiencing.
I hope this info is helpful to you.
Anonymous
  • Posted on Jan 16, 2011
SOURCE: Put in diagnostic mode. Pressed
the washer maching indicator sed that the maching is not level it worck 1 second and stop
2answers
Diverter valve clog
Take the diverter valve out remove the brown wax solenoid don't get it wet.
and un-clip the casing carefully not to break clips,
remove all lint jammed in the hinge valve,
Non energized wax solenoid outputs to drain pipe
reassemble and test.
Water sprays out and runs on floor during final spin cycle.
Sounds like a clog, either the drain tube, drain hose, or drain pump/diverter valve.
  1. If your drain hose is connected to a drain tube/pipe, it's possible there's a clog in the plumbing somewhere. Running a snake through the drain tube should fix this
  2. Disconnect the drain hose and look for a blockage. Sometimes lint, or paper will become lodged inside the hose and water will back up
  3. The drain pump/diverter valve is a common place for a backup to occur. To inspect the drain pump, unplug the machine and disconnect the drain hose from the drain tube. Put down a blanket or towel and tilt the machine forward. At the bottom of the machine you will see the drain pump with a hose connected by a clamp. Using pliers, disconnect the clamp. There may also be a mounting screw holding the drain pump in place. Unscrew the mounting screw. Now the pump should pull away freely. Using a small flathead screwdriver or tweezers or even needlenose pliers, you should be able to dig out any obstruction. Typically paper that has fallen out of pockets will get stuck in the drain pump forcing water in the other direction, causing it to spill out onto the floor.
Below is a helpful video to both check and remove a drain pump / diverter valve.
6helpful
I am getting service code 37, what does that mean and how can I fix it?
It's error code 37 and it means pump blocked error. Either the drain hose is clogged or kinked, the diverter valve has failed, or the pump itself is restricted or not working at all. Check to make sure that the drain hose is clear then disconnect power and lay the machine on its front on a cushioned surface to access the drain pump and the diverter valve. Remove the pump's inlet and outlet hoses then check and clear them from any debris that may prevent water from draining out. Check the impeller for any damage or restriction. Make sure the impeller is not frozen or blocked.
Check the diverter valve for the same condition as the pump described above. The diverter valve is where the drain pump and the recirculation pump inlet hoses are attached from. Make sure the diverter valve is in the drain position while the drain pump is working. Replace the drain pump and/or the diverter valve if deemed necessary.
3helpful
Hi, my washing machine is emptying the water as it is filling up on the wash cycle.
Hi Kala just read your posting.Is your machine draining into the laundry sink or some place else?If it is draining into the sink then the problem with your machine is the divert er valve.The diverter valve is in the drain out position when it should be in the recirculate position.There are 2 reasons that the valve is in this position,The 1sr the diverter is faulty or the 2nd the control module is faulty.Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
1helpful
3answers
What does fault code 51 mean?
Error code 51 usually means a faulty diverter valve. Try and run a wash cycle, and observe the drain hose. If water comes out, the diverter valve should be fine, if no water comes out you should take your diverter valve out and check for debris, or continue to read through the following possibilities of why your washing machine is acting up, and the actions to take.
1. Diverter valve
Action - Check diverter valve continuity. If open circuit, replace diverter valve.
2. Motor Controller Board (drive circuitry blown).
Action - Replace Motor Controller Board
3. Diverter valve harness/connectors.
Action - Replace wiring harness
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
3helpful
I have a gwl10 and during the wash cycle there is water coming in but the drain pump keeps running during the fill cycle.
The pump itself is supposed to run during the fill portion of the REGULAR cycle. It is supposed to be mixing the incoming fresh water with your laundry detergent and pouring the solution on your clothes as the tub rotates slowly. If the water is draining out of the machine, then there has been some sort of issue with the DIVERTER VALVE. It either has a broken lever on it or an object has become wedged in it, holding it open all the time. If you try the PERMA PRESS cycle, you will probably find that cycle will work, as it does not use the recirculate function.
I would check the diverter valve first. You can tip the washer back and remove the hose clamps with no tools and shine a light up inside and look for an object. You also can inspect the lever and will clearly see if it is broken.
If the washer needs a diverter valve, the part number is a 426862P and is easy to change. You can get them from Fisher Paykel Parts:
http://www.fisherpaykelparts.net/111-4/Diverter-Valve-GWL10-11-15.php
They also have downloadable service manuals (but I have pretty much told you what you need here)
Here is the GWL10 manual:
http://www.fisherpaykelparts.net/115-15/GWL10US-Service-Manual.php
Fisher paykel gwl11
1helpful
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
