Ccfl screen
all this old are dead or bad. or turn yellow. all do.
all did.
all you can do is turn up the brightness or replace the tubes
CCFL are back lamp tubes. for the SCREEN
CQ58-nnn what, what it the full service tag Partnumber.
ill toss the 50 sided coin and land on cq58-100
the 100 model, is LED and not CCFL lamps
so what OS is running? Windows 7?
i yes, see the users guide on bightness.
read page 26
the magic F3 key.
if the key fails, that means, the drivers loaded on this pc are wrong.
http://h10032.www1.hp.com/ctg/Manual/c03308662
correct drivers are alway here at REAL HP (we are not hp)
im picking w7-64bit now, if not 64bit go back and change that first.
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq58-100-notebook-pc-series/5259203
SOURCE: I have a compaq r3000 laptop computer. I need to
Select Control Panel - Hardware and Sound - Power Options ... Or, there could be a function key (press Fn and one of the F1 - F12 keys)to adjust brightness and contrast.
SOURCE: How do I adjust the screen brightness on a HP
Hi, Actually, the problem here is you don?t have any options in windows XP to increase the brightness without using keyboard. HP does not provide any utility with the OS as it is OEM. Try this · Click on start > Click on control panel..... · Click on power options.... · Click on " Change settings plan "..... · Adjust the brightness and save the plan..... And exit... that should work.... OR Replace the keyboard and get the all things working
SOURCE: Compaq 510 function key not working in xp I
Please install the hotkey utility from hp website
SOURCE: can get the battery out of my compaq cq58-252sa laptop
On a jammed switch for the batt on the (old) compaq I would take in for repair so is not you the done that damages anything around the battery casing.
