Question about HP Pavilion dv6000z Notebook
Hp compaq nc6400 not turning on - HP Pavilion dv6000z Notebook
SOURCE:
philmik
  • 107 Answers
SOURCE: where can i download recovery CD for hp compaq
Some info on recovery. Sometimes they make hidden Recovery HDD partition. If you won't be able to recover get new OS a put a fresh copy it's always a better way for your PC. If you need to save some files from previous installation you can use some of the Linux live CD's. My favorites are Knoppix, Ubuntu, Mandriva One.
Posted on Apr 26, 2009
parrotheadpc
  • 2600 Answers
SOURCE: my hp compaq nc6400 doesn't turn on. the green
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Posted on Oct 12, 2009
nonontech
  • 4737 Answers
SOURCE: Can I obtain a manual for a HP Compaq nc6400?
You can find all the required manuals for your Machine from this link:
click here to open the link and select from the available lists
Here's another called QuickSpecs (click here to download)
All the files are in pdf format, if you don't have a pdf reader, you can download one from here: adobe pdf reader
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Posted on Jul 25, 2010
  • 62 Answers
SOURCE: I switched on HP compaq
I too had same problem and I guess you too have the same problem as mine. VGA adapter is not working anymore. Hardware failure. You may need to change the motherboard.
Posted on Nov 29, 2010
SOURCE: i forgot my power-on password
l forgot power on password pls my me
Posted on Mar 22, 2011
Drivers vga download hpcompaqnc6400
Go to hp.com for drivers on an hp machine. They will be correct and up to date.
Jan 21, 2014 | HP Compaq nc6400 Notebook PC - Intel Core...
While using my laptop hp compaq nc6400 the screen turns into blue
Reinstall video card drivers. Be sure your laptop isn't overheating.
Apr 06, 2013 | HP Compaq nc6400 (GJ982US) PC Notebook
I have hp compaq nc6400 1.66 ram 1gb but duraing windows installation very slow plz send me soulation
Firstly you have to do a locally or remotly backup of all your documents cause in this process you may loose some of your vital document. Check to see if your Operating System (OS) is up to date. Or you can do a Restore if you have creat One. Its a Software issue and once you Re-install your Operating stsrem all will be fine.
Dec 05, 2012 | HP Compaq nc6400 Notebook
I wan to reset jumper on hp compaq nc6400 laptop
refer to manufacturers site for correct positioning.
Jun 20, 2012 | HP Compaq nc6400 Notebook
HP Compaq nc6400 notebook user manual required
Get onlineand got to www.google.com In the google search box type: "HPSupport" or "Compaq Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look throughout the site for Manuals.
May 23, 2012 | HP Compaq nc6400 Notebook
When i play video in my hp Compaq nc6400 laptop, the picture stuck and play. also it late to display when i turn it on.
open task manager by pressing ctrl+alt+del at same time.
check performance tab
if indicate CPU usage above 50% constant mean some background application is working, could utility or virus.
scan with good and light antivirus.
Mar 08, 2011 | HP Compaq nc6400 Notebook
HP Compaq nc6400 won't keep any BIOS settings
HP Compaq nc6400,,is the bios pin on correct jumpers?
https://support.hp.com/rs-en/document/c00363478
Dec 30, 2017 | HP Compaq nc6400 Notebook
HP Pavilion dv6000z Notebook Logo
51 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
