Show diagram please
SOURCE: Hi. I would like to connect a Bose controller
Tech data sheet with diagrams:
http://www.bose.com/pdf/professional/802III_techdata.pdf
In a nutshell, the controller would go between any preamp Stereo OUTput and a dedicated amplifier INPUT. You really don't have much choice in the matter. The 802's and their controller are part of an inseperable system.
The Bose 802/901 family uses full-range speakers instead of traditional woofer/tweeter combinations, so they compensate for the response limitations at the extreme frequencies by using severe electronic modification of the program material. Hence, they are a system, functionally inseparable, but the results are outstanding. Consequently, they need a dedicated amplifier so they alone get the processing provided by their electronic component.
I don't have any data on your mixer/amp but if you can't insert the conroller logically between the mixer and its amps then you'll have to get separate dedicated amplification for the 802's, with the controller between the mixer and that amp.
