The phone jack works and have power to unit help please
SOURCE: tru 9485
Look in the handset menu under global setup, scroll to CIDCW, click OK, and set to on or off depending what you want.
had the same problem and was trying to get solve the menu in the base
SOURCE: base unit line 1 is flashing no dial tone
We followed your instructions and are not sure what worked, however, this AM phone line is working.
SOURCE: message box says full, but machine shows 0 messages
Do you also have a telephone-company provided answering feature on your line (such as Verizon's home voice mail)? I've known other people who got this service as part of a package from their phone company without realizing it, and had just the same trouble. Your callers may be reaching that instead of your answering machine.
Most companies alert you to waiting messages through "stutter dialtone." When you pick up your handset you'll hear two or three short bursts of dialtone before it goes steady. This is your signal to pick up your voicemail messages. Are you hearing this?
Check with your telephone service provider if you are unsure. If your telephone answering machine says it hasn't taken any messages, the full box message must be coming from them.
Place the phone near the Transmitter if it says the same return it to the store
SOURCE: House Phone not working
It's not an assumption, it's fact. It's not their problem, it's yours, since you get dialtone at the box.
With a meter or continuity checker, you could figure out if there is a short in the wire. Without those items, the best way to check it is to first look for a broken wire right at the interface. Then, if that's not it, plug the jack into the protector and IMMEDIATELY go to a phone and see if you hear dial tone. It will go to a busy if you wait too long. If you hear dial tone, then you probably have something off the hook or using the line. If it's still dead, then you probably have an open wire or short.
Technical training is beyond the scope of this forum, but a "cheap" meter (VOM) from the "Shack" is probably less than $15. If you unplug the line from the box outside and set the reading to ohms, your meter should read infinity or no resistance on an idle line. After you get that condition and plug the line back in, a meter shold read 48-52 DC volts on a working phone line.
Carl
