If you turn the tv off for about 1020 seconds, turn it back on and see if you have a clear picture, if not it sound like a power supply problem in the tv. but if that did not solve the problem, the
picture board on your tv is now malfunctioning or as gone bad, it means the
board of your tv has developed fault and will need to be replace.
I
advice you replace the picture board on the screen of your tv to
solve the problem.
There was a software update early this morning which caused your recvr to go to recovery mode until it downloads the new software which takes about 4 hours. Once this is done you should be just fine!
Wharfedale LCD3210HDAF this tv was working fine the night before ..
when i turned it on in the morning the screen came on then instantly
went blank .. although the sound is fine i am unable to get any on
screen including menu an volume information and of course can any one help ??
Ok, my phone had the same problem. I took the face plate off and the screen out and there's actually a little connector that connects to a board behind the screen(can come unplugged for replacement). I fiddled around a little with it and it worked fine. about a week or 2 later it happened again. I tried fixing it again and it would just flash white>black>lines>white, repeat. I know my phone's taken a bit of abuse, dropped down a road, soaked in rain, but it always worked after. These phone screens aren't meant to take abuse. Problem; the phone screen died. Solution; get a new screen.
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
