HP LaserJet P2055d Printer Logo
A
Anonymous Posted on May 02, 2014
Prints blank page - HP LaserJet P2055d Printer
How do I Fix Brother printer printing blank pages issue of my Brother printer?
Completely or partially blank pages when printing from ...
Brother-USA https://help.brother-usa.com > answers > detail > a_id
Completely or partially blank pages when printing from Windows or Macintosh computer only. 1. Place a document with text or an image on the flatbed or in the ...
The printer prints blank paper - Brother HL-5240
iFixit https://www.ifixit.com > Answers > View > The+printe...
Sep 5, 2016 · 5 answers
Here are the steps to fix the brother printer printing completely blank pages issue. 1. First of all, you should restart the devices, ...
Fix brother printer printing blank pages
brothersetupsupport.com https://brothersetupsupport.com > fix-brother-printer-...
Jan 23, 2023 - Why brother printer keeps printing blank pages · Ink cartridges have jammed or there is a paper jam. · The printer head is blocked or jammed. · The ...
Why is my printer is printing blank pages
Printer Printing blank page issue can be occurred when you have low or dried ink cartridge, blocked nozzles, dirty print head and ink cartridge installed improperly. Follow the troubleshooting steps to fix printer printing blank pages:
·Restart the printer
·Check printer ink cartridge
·Clean the printer print head
·Update the printer drivers
Follow more steps to fix the Printer printing blank pages issues
2answers
Prints blank page
Have you checked the print que
Printer problems can be a real hassle.
From time to time, due to document layout or settings on your computer, in your software of choice, or even on your printer, a blank page may get "printed" with the rest of your document.
Fortunately, this issue is a simple one to troubleshoot.
Click "Print Preview" when you are finished with your document and ready to print.
Observe your document.
If you see an extra, blank page, you have created a second page.
To delete the second page, close Print Preview, go back into the document and eliminate any blank lines in your documents that you may not need.
You may also find an inadvertent page break at the end of your document.
Place your cursor on its symbol and delete it.
Locate the symbol by clicking on the Show Formatting paragraph icon in the toolbar.
Circumvent this "ghost page" if you do not see a second (or additional) blank page in Print Preview.
Specify the number of pages you wish to print, within the Print dialogue box.
This is typically done by selecting the "Print From" option, then entering the page numbers desired.
If your document happens to be ten pages (without, of course, that final blank page), then enter in the "Print From" field the numbers "1-10".
This will print only pages 1 through 10, without an eleventh (blank) page.
Canon iR C6800 prints leading and trailing blank pages
There is an option in the print driver to print a separation page (typically just a blank page unless you specify otherwise) so that each person's print jobs can be differentiated easily.
This option probably got enabled somehow on her PC. Have her go into the print driver's properties (right click on the Canon in the list of printers and select Properties) and look for the option that says separation page or separator page and deselect it. Then click Apply or OK, and it should be good.
2helpful
2answers
I get blank pages when printing. Sometimes all pages are blank, sometimes first and last page print, with blank middle pages.
hi,check your printing setting and then print.
or....
uninstall the printer then install the printer again then printer has default setting and print the paper.
sometimes printer current pages print wich is selected by setting.you must select all the pages.
to change the setting,,,
1-open control panel then open printers and faxes then check seeting.
1helpful
2answers
Printing Blank Pages
Try checking the ink cartridges and make sure they have ink in them or it will keep printing blank pages. Then try printing a test page by going to control panel, clicking on printers and faxes and right clicking on your printer and going to properties. Then go all the way down to the bottom of the page and click print test page. It will clean the printer cartridges and align them to print correctly. It should work after that.
12helpful
3answers
Hp 1320 prints blank LOSER SPAM ALERT 1-800-532-4187
My HP 1320 printer is printing blank pages and it will not even print test pages etc
1helpful
Prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
1helpful
k24674
Grand Canyon Tech
Grand Canyon Tech
