SOURCE: Brother Printer Setup & Support Call 1-(805) 225-6690 We are 24 Hour Available Call Now For Help...
The disconnect-problem was caused by the settings of the WiFi-router.
The settings are:
Capture(wlanadv.beacon)
Beacon Interval:
Capture(hwlad2.def)
Default: 100,
Capture(hwlad2.milli)
Milliseconds,
Capture(hwlad2.range)
Range: 1 - 65535)
Capture(wlanadv.dtim)
DTIM Interval:
Capture(hwlad2.def)
Default: 1,
Range: 1 - 255)
Capture(hwlad2.frathrh)
Fragmentation Threshold:
Capture(hwlad2.def)
Default: 2346,
Range: 256 - 2346)
Capture(wlanadv.rts)
RTS Threshold:
Capture(hwlad2.def)
Default: 2347,
Range: 0 - 2347)
This gives an optimal performance of the router, The default setting work fine for the printer, but gives less performance.
I now use a seperate wifi-router for the printer.
All is fine now.
SOURCE: I am trying to connect Nokia E66 thru Wifi to DSL
Friend iam also facing the same problem, while connecting Nokia E66 thru Wifi to DSL 2640U of D-Link and i an not successful. Mobile gets connected but it gives an error ''no gateway reply'' or ''gateway error''
SOURCE: Belkin Play N600. Acer Vista laptop. Wifi only,
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
SOURCE: I cant connect my dell laptop nor detect D-Link
You may check your network adapter on your computer. Just go to device manager and check for network adapter. If there is a missing network adapter you may look for the driver for the correct Dlink network driver.
