Question about Jacuzzi Signa 6 Whirlpool JAC-B540...
How to clean jacuzzi pipes and pumps - Jacuzzi Signa 6 Whirlpool JAC-B540...
Hayward Electronic chlorine generator bond to Jacuzzi magnum 1000
when i done mine i cut the pipe and glued another connector in to the pipe that goes to the jets ,
Apr 10, 2012 | Pool & Spa
Jacuzzi hot tub pump. Put new pump and motor in water wont circulate but can here pump running.
Check your suction plumbing to be sure it is sealed and tight. Then force some water through the pipe to see if anything is blocking it.
Nov 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
NO PREASURE
Most likely the impeller is clogged, or there is a blockage on suction side of pump/plumbing. Is the basket clean? You may also have an air leak. If the pipe coming into the pump, or the pump lid not sealed, or if a leak at a union, or valve coming into the pump is allowing air in, then the pump may not prime or move much water
Sep 10, 2010 | Jacuzzi Impeller, L - 3/4 H.P
I have a jacuzzi magnum force pump I am trying to plumb the pvc into the pump I lost the screw down union what size do I need to buy and where do I buy a union to fit this pump
Go to your local pool supply get a union to match the sise of your pipe ... or ... just glue it together today and add the uniion next time you have to take that part out.
Jun 05, 2010 | Jacuzzi Cyget In Ground Pool Pumps
The pressure at the jets is less than what it should be
20 is a good number. You have a 1.5 motor and 1.5 or 2.0 pipe?
Oct 19, 2009 | Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM...
Which valve do I use on the Jacuzzi Magnum 1500 to drain lines
There two plugs on your pump, one one the side of the pot at the bottom and one dead center of the pump housing on the front. this will only drain your pump if you live in cold country and are winterizing you will need to drain all your equiptment filter, heater and any thing else. then you need to drain your pipes and seal them at poolside to keep the water out.
Sep 26, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
My jacuzzi pool pump cracked so I need to replace it. Jacuzzi is no longer making parts, so what would be a good brand where I could still use the same pipes, filter, etc.?
here's a site where I found tons of jacuzzi parts and accessories.
http://calwesthot1.reachlocal.net/AdvancedSearch.aspx
under select catagory scroll about half way down to jacuzzi pumps and hit search.
If you find what you need can I borrow the jacuzzi .. lol
Jul 31, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
I have a jacuzzi 1/2 hp submersible well pump. Does this need any regular maintainance to keep it happy.
No preventative maintenance is necessary. However, a happy pump always has water above it and should not pump sand. If the water level in the well is below the pump/motor they will overheat. If this is a problem your local pump company can install a module to protect your pump from this type of event.
Please rate this answer.
Jul 03, 2009 | Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire...
Jacuzzi leaking
The best way is to cut the pipe out and repipe. I'm guessing that the pipe on this is a ridgid schedule 40 PVC. On the new units, they don't use ridged pipe much anymore. If you do decide to cut out the pipe and replace it, it is possible you might have to replace one of the jets depending on how they are mounted to the pipe. Make sure you use primer and a glue that is made to use on wet pipes. You can get it at the hardware store and it's blue. It's the type that you can use on sprinkler systems. You can try the epoxy but you need to make sure that the joint is dry and clean before applying it. Like I said, the best way is to cut out the old and replace with new.
Mar 21, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Jacuzzi Signa 6 Whirlpool  JAC-B540... Logo
41 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
