Igloo Cooler Igloo Portable Countertop Ice Maker, White Logo
A
Anonymous Posted on May 02, 2014
How can I fix it if it stopped making ice?
Model ICE102
Hello, I have a portable ice maker model 102C igloo . the machine turns on but will not continue the cycle and the ice full red light comes on. Any answers to this problem are welcome.
The tray full may be triggered or stuck or another problem may exist. Look for what senses the ice being full and also check with Curtis support:
(another person was tld to do this and it workd:
1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hours.
I included some links for your convenience. Good Luck
1 How to fix portable ice machine part 1 of 3
Troubleshooting Portable Ice Makers
Igloo ICE102 WHITE User Manual Troubleshooting Guide
Apr 29, 2016 • Freezers
2helpful
3answers
My hoshizaki ice machine KM-900mrf model beeps 3 times and stop making ice. After reset it starts, but stats beeping again after an hour.
Have a look at the side of the evaporator; there is a probe (thermistor) attached to it that tells the control board when to initiate the harvest cycle. make sure it's clean and attached properly and doesn't need replacing. If hitting the float switch initiates the harvest cycle it sounds like you have a blocked/ scaled water tube or switch housing. take off the bottom of the switch assembly (black rubber bit) and clean through to the water chamber. run a cycle of descaler before trying again.
Leak from freezer into refridgerator, near the back.
You did not mention what Model and Make it is. That could change a fix.
Just a generic fix, assuming the unit its not too new, the first thing you want to do is turn the water off that is feeding your ice maker. Behind the refer on the wall. Be careful to not kink the water pipe pulling out and putting back the refer during your repair.
If stopping the leak into the refer was accomplished by turning off the water, now your confronted with how old is the refer and is it worth digging around and finding the actual leak. If the leak is in the wall of the refer (not the house wall), basically, just forget it, live with it and buy some ice trays. If you want the ice and it is really old, you may want to take this opportunity to replace the unit.
This would be my first assessment, not knowing age, make and model number. Sorry, wish I could be more helpful.
kindly,
Jim
F-330bah-c stopped making ice & unit is 1 month old
it should be under warranty . is the water shut off to fridge . ice maker could be bad . make sure water to the ice maker is on just check your water line . a very easy common mistake and very easy fix if the water is not turned on to the ice maker it wont make ice . hope this helps let me know how it gos
1helpful
Samsung refrigerators
if the filter is dirty enough to where it stops the flow of water then yes.a replacement of the filter should fix the problem for you
My ice machine model f-450 mah makes ice but once it's full the water keeps running and runs out of the machine how do I fix this?
Make sure the plug in the water tray is secure and not allowing water to drip out. Check to make sure the float turns off the flow water once up to level.
1helpful
I have a model # f-450 mah ice machine. After the bin gets full of ice it stops making the ice but the water continues to run and runs out of the machine. Any ideas on how to stop this?
Sounds like the water valve is stuck. Probably needs replacing. Turn off water after machine shuts down and see if water stops. If it does, water valve is most likely the issue.
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 • Freezers
2helpful
2answers
Jen aire ice maker not working
change filter and defrost water lines if frozen
Top Igloo Cooler Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Igloo Cooler Freezer Expert? Answer questions, earn points and help others
