Have lost task bar, email facility, games bookmarks et al
Dont know why that would have happened in an update? something else must have happened. MS updates do not cause those type of problems. what PC do you have, what was happening when this happened. you can reinstall google, the folders for favorites should still be on computer unless you were using Chrome and deleted it somehow. If so, then you may be lost...if using internet explore then
the favorites are still there. since you said 'bookmarks' you probably using Google Chrome. If deleted somehow, then you may be in trouble. You can reinstall from web BUT your bookmarks, may be gone. sign in to chrome after reinstalling and your email will still be there-you may have to find all your bookmarks again though. knowing what happend, what you were doing would make answering this easier.
SOURCE: task bar displays
Windows usually hides the task bar icons you have not used recently.
If that is the case, you must have a small left arrow < at the left of the last icon displayed. Click that arrow and the hidden icons will be displayed for a short while.
Usually the safely remove hardware is present (shown or hidden) whenever there is a removable equipement.
For the local or dial up connection, you can configure your computer to display it on the task bar. Here is how to do it in Windows XP
1. Press the Start button on the left, choose Connect To > Show all connections. You will see all your connections, each one symbolized by an icon.
2. Point the mouse cursor to the one you want, Right Click Mouse button, then Properties.
3 Under the General Tab, put a check mark in Show icon in notification area when connected
4. Click OK.
Hope it helps
