What is the cause of yellow fluid leaking onto the serpentine belt of a 2000 dodge grand caravan in the vicinity of the water pump?
SOURCE: serpentine belt diagram:
The belt routing diagram is located on the top radiator cross member by the hood latch. You should see it when you open the hood. If it is not there, all Chrysler, Dodge, and Plymouth minivans, from 1993 to at least 1999, used the same 3.3L engine setup, so find someone with one and look for the diagram where I described.
SOURCE: How to replace serpentine belt for 2000 Dodge Grand Caravan?
Mine fell off twice so far once when going through snow and other was going through rainstorm had to use jack wrench to pry down and slip on belt which was hard to do and don't advise you to try. Ok the pulley directly under the alternator and in the middle of 3 other pulleys is the one that is the tensioner. To do this right use a 15 millimeter or 5/8 socket or open end wrench, the longer the handle the better so you can get good leverage maybe you have a pipe to slide over handle. There is a diagram of the way the belt goes on under the hood. I have a 2000 Dodge Grand Caravan
SOURCE: Dodge 2005 Grand Caravan water Pump replacement
JUST COMPLETED THIS JOB TODAY. MAKE SURE THE ENGINE HAS COOLED DOWN . IT TOOK APPROX 2 1/2 HRS. DISCONNECT THE NEGATIVE POST ON THE BATTERY. JACK UP PASSENGER SIDE FRONT AND SUPPORT ON JACK STANDS. REMOVE PASS. FROUNT TIRE. DRAIN RADIATOR INTO CONTAINER FOR PROPER DISPOSAL OR REUSE. USING FLOOR JACK PROVIDE SLIGHT TENSION ON OIL PAN WITH A SHORT 2 X 4 WOOD PIECE TO PROTECT OIL PAN. LOOSEN 3 ENGINE MOUNT BOLTS ON PASS. SIDE OF ENGINE COMPARTMENT. ALLOW APPROX 1" BETWEEN SHOULDER OF BOLTS AND MOUNT. LOWER ENGINE UNTILL BOLTS ARE SET ONTO MOUNT. REMOVE ENGINE SPLASH SHIELD INSIDE WHEEL WELL OF REMOVED TIRE. LOCATE WATER PUMP AND LOOSEN 3 PULLEY MOUNTING BOLTS (THIS IS WHILE BELT IS ON PULLEY) REMOVE SURPENTINE BELT AND CONTINUE TO FULLY REMOVE THE PUMP PULLEY. IT WONT COME OUT AS THE PUMP & PULLEY HAVE TO COME OUT TOGEATHER. REMOVE 5 WATER PUMP BOLTS AND CAREFULLY WORK WATER PUMP OUT BETWEEN THE ENGINE AND VEHICLE FRAME. CLEAN ALL MATING/GASKET SURFACES AND BOLTS. USING A SMALL AMOUNT OF TACKY SEALENT TO INSURE THE NEW WATER PUMP SEAL STAYS IN PLACE, THE INSTALL IS PRITTY MUCH THE REVERSAL OF REMOVAL.
GOOD LUCK, REMEMBER TO TIGHTEN ALL BOLTS TO MFR SPECS AND BLEED THE AIR OUT OF THE COOLANT AS REQUIRED.
SOURCE: Dodge 2000 minivan,water pump leaking
Make sure it's cool, pop the radiator cap, Remove the shield on the passenger side between the tire and front of engine. Relieve the tension on the serp belt,draw yourself a diagram of the pulleys and belt routing in case the sticker is gone on the strut tower, remove the serp belt. Take the bolts out of the pulley on the front of the water pump (3). Remove the lower radiator hose at the front cover to drain the coolant. Remove the 6 mm bolts holding the water pump to the front cover housing. tap on the pump with a rubber hammer. Install a new gasket on the new pump, and a weap hole diverter in the pump (round black about hte size of a quarter), use old one if there's no new one. Install pupm and tighten bolts snug with a 1/4" ratchet. Install pulley and 3 bolts. Install belt, top off radiator with 50/50 mix green coolant. start engine and run to operating temperature,make sure the belt is seated in all of the pulleys and is running true, radiator fans should come on. Shut engine down and let cool overnight. Check level in radiator and overflow bottle, top off as necessary.
SOURCE: I need a diagram for a 1994 dodge grand caravan se
Try this
Testimonial: "you did find the diagram that works, thanks."
