Alligment
SOURCE: I can't get my HP
Hi Pattyrose,
The OK button is the Button 7 to make a black & white copy or Button 8 for colour copy.
SOURCE: message on printer printer calibration load plain
Well this is simple but iratating
There are paper feed from begining to end Im gonna say this is a manuel to static printer this is simple in the sense that you do not need to really do anything accept keep it clean. When you drop the paper in the printer you need too let feed dont stick it in there let it sit in the carrier and the printer should grab it if not You may have gotten a lemmon Take it back and tell them HEY IM NO ******!!!!!!!! You know that
SOURCE: WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN
You have the settinigs on the printer wrong. There are two things you need to do:
1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
SOURCE: printer saya bila dihidupkan selalu
Check your paper tray and make sure you have the paper loaded correctly and that the paper guides are snug against the paper. There are settings on the menu that you can make sure they are set to plain paper
