Pride Jazzy 1103 Ultra Standard Power Chair  Logo
joe tessier Posted on May 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red light flasheswhen on. 4times turn off - Pride Jazzy 1103 Ultra Standard Power Chair
oregoon
Level 2:
  • Expert 175 Answers
  • Posted on May 08, 2014
oregoon
Expert
Level 2:
Answers
175
Questions
0
Helped
107781
Points
363
This flash code is indicating that the right motor has a bad connection. It rarely is the case that the cable leading from the motor to the controller comes loose...it usually is the case that the motor has overheated and burned out a winding that makes it....toast, unfortunately. This can occur from getting stuck in the mud, sand or getting the chair trapped in a doorway, for instance, and trying to drive it against strong resistance. Also, I should add, that sometimes the controller "lies", and it might be the left motor. Swap the cable from left to right and right to left and turn on the chair and see how many flashes. If is shows three, then the right motor is probably shot. Also, and it happens a lot, if the controller(the box that the cables run into)has been damaged somehow, it may be giving you a false fault code. You have to have a known good motor to plug into the right motor connection, fire up the chair and see if that clears the fault. Either way, it is not a cheap, easy fix. Sorry for your problems.
1helpful
Hi, r15v2 2013model/eng turning but not starting. eng warning lights showing- eng light blinks 4times slow then8times fast,what does that mean?
According to a post on Fixya, the engine warning light blinking 4 times slowly followed by 8 times quickly is a sign of a throttle position sensor malfunction. The post also suggests that the engine not starting could be due to a fuel pump malfunction or a faulty spark plug.
Panasonic tv model txp42s20b red light flashing 4times over & over
Hi Muhammad
4 blinks Power SOS P-Board
BOARDS DESCRIPTION: P MAIN Board = Power Supply (VT30 Models) - Non-serviceable. Must be replaced for service.
P SUB Board = Power Supply (VT30 Models) - Non-serviceable. Must be replaced for service.
P Board = Power Supply (All Other Models) P2 Board = Power Supply (All Other Models)
Hope this helps
Len...
Repairs for a sony kv-27s42tv
Over-voltage protection circuit energises. Check the output voltage tht comes out of its SMPS section to main board. If this voltage is more than/less than normal, this kind of fault can occur. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
SONY T.V. MODEL KV-25ST12 4TIMES BLINKS STANDBY
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505. Check the vertical output IC, especially to the solder terminals for any loose soldering points. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
SONY KP-65WS510 WONT TURN ON RED LIGHT BLINKS 4TIMES AND THEN OFF THEN 4 TIMES AND OFF ETC ETC
Hi, My guess is that you don't have adequate power for your flat panel. By all means do not use long extension cords. Try a different wall plug. You must have 120V ac to work. Read your manual that came with it. Good luck
Pictures not appear
this could be a leaky picture tube. will require a crt rejuvination machine to clean the tube elements
2helpful
2answers
Doesn't power up. Red standby light flashes.
How many times does it flash?
Odds are the A board components. Let me know how many times the stand-by light flashes, and I'll tell you want the fault might be.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
