These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
SOURCE: Problems with the picture mode on my samsung 46''
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
SOURCE: my tv turns on but no picture or sound
power pack capacitors have failed they will need to be replaced with new ones and that should repair the tv, soldering skill is required to do this or replacement of the entire power pack.
hope this helps
SOURCE: Red light flashes but TV wont turn on
If you dont have the led light on when plugged go ahead and replaced the powerboard, but if your led light is on when plugged then you will need to replace the mainboard.
Hope this info help you.
SOURCE: tv wont turn on power button just keeps flashing
The issue here is the power supply, Now what may have caused this issue is unknown I am not there to look at it.
if you know eletronics:
Now things to check:
1. Capacitors on poer supply
2. relay
3. transformer
Otherwise consult a local repair shop as soon as you open a TV your beyond what we call user friendly repair. when in doubt contact a local expert to have a peak.
thanks for using fixya.com please do leave your feedback and ratings for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: keeps turning itself off.
Check the power supply board for overheated, bulging components, esp. the can capacitors. Replace with similar or higher rating caps you can order on the net. Hope this helps you.
