Microsoft Windows 98 for PC Logo
A
Anonymous Posted on May 02, 2014
Windows 98se video drivers
I have an old computer with 98SE and some specialized software that won't run on newer op sys. I had to replace my HD and reinstall 98SE. Previously, somehow, I had generic drivers for higher resolutions than 640 x 480. Are there any generic drivers for higher resolutions?
wd neojoneswd
Level 2:
Novelist:
  • Expert 222 Answers
  • Posted on Dec 27, 2015
wd neojoneswd
Expert
Level 2:
Novelist:
Answers
222
Questions
Helped
29281
Points
300
Not for 98SE i believe. a great OS but MS most likey deleted those from their servers long ago. if you can find someone else who has a system with 98SE you may be able to copy and install them from them. someone who is really old and smart "CE" maybe could program them:) for you but, you should have backed up your system and drivers before this repair was needed
4 Related Answers
Anonymous
  • 45 Answers
  • Posted on Dec 06, 2007
SOURCE: Broad Band internet connection under WINDOWS 98SE.
i think it is because 98se is not compatible with broadband or wireless, you know what i mean, if i were you i would upgrade that OS to xp, very cheap these days
hope this helps
Anonymous
  • 45 Answers
  • Posted on Jan 16, 2008
SOURCE: windows 98se to windows vista
man connect them via lan cable make settings on the vista comp
it will recognise windows 98
and not otherwise
make u r vista computr server and the other client then only it will work
why bother all this borrow some thumb drives frm frnds and copy the files
Anonymous
  • 106 Answers
  • Posted on Jun 03, 2008
SOURCE: windows 98 SE
if you need an operating system and would not mind using linux (an alternative to windows) look on the www.puppylinux.com site and see if you would like to try it. the download is about 80meg and it runs very fast on all the computers i have used it with. or try looking on softpedia for a free download of the outdated windows xp install disks. or you can buy some disks from ebay. but i reccomend trying puppy linux, it is free and you have nothing to lose.(the disk is a live boot disk, so it should just run off the cd)
Anonymous
  • 100 Answers
  • Posted on Dec 24, 2008
SOURCE: Need a driver for USB2 external hard drive to work with Win98SE
1) the device should have come with install software, use that. if you dont have it try these ->
2) plug it in and go into the Device Manager,
Control Panel -> System -> Hardware -> Device Manager
it might be "unknown" but if it's in there click on it, click on "Install Driver". it will ask you to let it search the web for a driver. allow it to do so. it may or may not find one.
3) OR go to the manufacturers web site and look for the SUPPORT link. you should be able to make your way to the drivers section. they may have one for you.
If these dont work --
What is the make model etc of the device, all the numbers please.
and please gimmie your pc info. make model processor , os, etc
Let me know :)
3Com Megahertz 3CXEM566 B 10 Mbps LAN+56K Modem PC Card Driver For Windows 98SE
https://www.driverguide.com/driver/detail.php?driverid=5372&si=9ea320d50a226c79eb7fb572e0673dd0
Try this link...I just confirmed that it does exist.
If you have any issues, Try using a Microsoft or a 3Com universal driver.
Last but not least, simply go on eBay for a vintage LAN card...that includes a driver CD that runs on Windows 98SE.
If you need further assistance, just reply after trying those possibilities.
I'm "A+" Industry Certified PC Repair Tech. If you can't find one in a box with driver disc, maybe I have some LAN cards.
Does this need an ISA or PCI slot?
Software windows 98se
It would be helpful if we knew the Make, Model of Laptop. If the Laptop is that old the hardware specs may not support a software upgrade to say Win XP or above. Windows 98se drivers may be a bit difficult to find. The software has been un-supported for many years, soon XP will be on that list. But it's possible with a search of the Make, Model of Computer and the OS.
Need to download software into my computer lost disc.
No special drivers are needed for Windows 98SE/ME/2000/XP/Vista and Apple OS9.1/OSX.
Need drivers to run windows 98se on dell xps m140
Microsoft (and Dell) stopped supporting Windows 98 a few years ago -- it lasted for over TEN years! So, it is *NOT* likely that you will find drivers for any computer that was "designed for Windows 2000" or "designed for Windows XP" or "designed for Vista".
So, in general, it is a _bad_ idea to connect any computer running Windows 98 to the Internet -- Microsoft has issued many "security-fixes" in the 4 years after they stopped supporting Windows 98 and Windows ME.
2answers
I want to transfer files from an old desktop running Windows 98SE to a new laptop running Windows Vista Home Basic. I have bought a Maxell 2Gb memory stick: gone to the Maxell eu site and downloaded - as...
It should be unzipped and path to the unzipped folder provided while installing new hardware, when Windows (after plugging in the stick) finds a new plug&play device and asks for the location of drivers.
Also, go to your newer computer and check the USB stick's drive properties - it should be formatted using the FAT or FAT32 file system. If it's formatted using NTFS, Windows 98SE will not see it.
1helpful
I have a simple question.
System Mechanic 8 is compatible with Windows 7, Vista, XP and 2000. I am sorry to inform you that it is not compatible with Windows 98.
If you go to the page below and look under purchase now, you will see a windows logo and a list of all versions of windows System Mechanic is compatible with.
http://www.iolo.com/system-mechanic/standard/
No istallation disc for hp deskjet 6940 for windows 98se
U can download the compatible software from HP.COM
choose "Software & Driver Downloads" and enter the product model # and select the correct O/S..
Download the Software first instead of straight away installing it..
Best OF LUCK !!
Can not get my printer to print from the computer
Unfurtunately you didnt tell us what pc system you run: Is it XP, Win2k or Vista?
The latter one wont be able to connect to your pc.
For the mfc 210c are only drivers for xp and win 2k, 98se avaiable.
You need another (newer) mfc (mfc240 or 235) if you run vista.
Anyway, if you run xp, download the aggrssive usb driver remover from the brother homepage and delete the drivers installed.
After a restart of the pc do have the mfc DISconnect from usb port (which must be one of the pc: NO hub!). Insert install disc and wait until pc software demands the connection to mfc. Connect now to pc usb. Let the software finish the installation. This should work for xp and win 2k/98se.
Usb external , teac HDU80/KIT HD....
You can get the driver on Teac's site. The 98se driver you download depends on your serial number, so have that handy.
Good luck...
Geno
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
